29594 Discussions
How to pass an allocated array to C?
AONym
New Contributor II
In a Fortran subroutine, I allocate an array. This subroutine calls a C++ function, which will store its results in the allocated array. I am having trouble passing the address of the allocated array to the C++ function.
Here is what I am doing now:
    REAL(C_DOUBLE), DIMENSION(:,:,:), ALLOCATABLE, TARGET :: output
    TYPE(C_PTR) :: pOutput
    INTERFACE
        INTEGER(C_INT) FUNCTION CFunction&
            (p1, p2, p3, p4, pOutput) &
            BIND(C, name='CFunction')
            USE, INTRINSIC :: ISO_C_BINDING
            IMPLICIT NONE
            REAL(C_DOUBLE), INTENT(IN), VALUE :: p1
            REAL(C_DOUBLE), INTENT(IN), VALUE :: p2
            REAL(C_DOUBLE), INTENT(IN), VALUE :: p3
            REAL(C_DOUBLE), INTENT(IN), VALUE :: p4
        END FUNCTION CFunction
    END INTERFACE
ALLOCATE(output(n1, n2, n3), STAT = allocationStatus)
    pOutput=C_LOC(output)
    err = CFunction(p1,p2, p3, p4, pOutput)
The C++ function looks like
extern "C" int LammSolve(const double p1, const double p2,
    const double p3, const double p4, double *output)
and stores values as
output=value;
This definitely doesn't work. The returned value of the output array looks as if its array descriptor has been overwritten by C++ (presumably by storing into output[0]). Is there a way I can pass the address of the Fortran-allocated array to C, without parsing array descriptors?
64-bit Windows 7, Visual Studio 2015, Intel Fortran XE 2017 u 4.
Arjen_Markus
Since the array descriptors used in Fortran are not exposed (at least not in the C-Fortran interfacing defined in Fortran 2003, there is a technical report regarding this aspect), you should not try to take advantage of that. The difficulty is actually quite simple:
means that you pass an address to C++ as void ** - you can use instead:
REAL(C_DOUBLE), DIMENSION(*) :: pOutput
which on the C++ becomes "double *", so the address to the first element of the array.
If you really need a void * pointer, then "TYPE(C_PTR), VALUE" will do it.
AONym
New Contributor II
 I changed the declaration to
and line
gets error #6364: The upper bound shall not be omitted in the last dimension of a reference to an assumed size array.   [POUTPUT].
Changing it to
   pOutput(1)=C_LOC(output)
gives error #6303: The assignment operation or the binary expression operation is invalid for the data types of the two operands.
So I guess I don't understand your suggestion; can you clarify?. The C function does need double *, although I could easily cast void * to that if necessary.
jimdempseyatthecove
pOutput=C_LOC(output(1))
Jim Dempsey
AONym
New Contributor II
 With the declarations
I get with
error #6351: The number of subscripts is incorrect.   [OUTPUT]
error #6633: The type of the actual argument differs from the type of the dummy argument.   [POUTPUT]
 error #6634: The shape matching rules of actual arguments and dummy arguments have been violated.   [POUTPUT]
 error #6221: The assumed-size array must be a dummy argument.   [POUTPUT]
 And with
  pOutput=C_LOC(output(1,1,1))
jimdempseyatthecove
you want something like this:
subroutine foo
    implicit none
    real, dimension(:,:,:), allocatable, target :: output
    real, dimension(:), pointer :: pOutput
    allocate(output(10,20,30))
    pOutput(1:size(output)) => output(:,:,:)
    output(1,1,1) = 123.456
    print *, size(output), size(pOutput), output(1,1,1), pOutput(1)
!    err = CFunction(p1,p2, p3, p4, C_LOC(pOutput(1))
! *** err and CFunction, p1,p2, p3, p4 are for you to define ***
end subroutine foo
Jim Dempsey
FortranFan
jimdempseyatthecove wrote:
.. you want something like this:
subroutine foo
    implicit none
Jim,
If there is a separate need for a local variable with a POINTER attribute, then it is a separate matter but otherwise it is generally better for most coders to stay away from variables with the POINTER attribute to avoid potential issues with such variables.
@Ann O.,
You can follow Arjen Markus' suggestion in Message #5 which was only to modifiy the INTERFACE block to include the VALUE attribute with your pOutput dummy argument.  Here's a complete example you can review and try out:
#include "stdio.h"
// Function prototype
int CFunction(const double p1, const double p2,
    const double p3, const double p4, double *output);
// Function implementation
    const double p3, const double p4, double *output) {
   printf("In CFunction:\n");
   output[0] = 99.0;
   printf("p1 = %f\n", p1);
   printf("p2 = %f\n", p2);
   printf("p3 = %f\n", p3);
   printf("p4 = %f\n", p4);
   printf("output[0] set to %f\n", output[0]);
   return(0);
module m
   use, intrinsic :: iso_c_binding, only : c_int, c_double, c_ptr, c_loc
   implicit none
   private
   interface
      function CFunction( p1, p2, p3, p4, pOutput) result( iret ) bind(C, name='CFunction')
         import :: c_int, c_double, c_ptr
         implicit none
         ! Argument list
         real(c_double), intent(in), value :: p1
         real(c_double), intent(in), value :: p2
         real(c_double), intent(in), value :: p3
         real(c_double), intent(in), value :: p4
         type(c_ptr), intent(in), value    :: pOutput  !<- note the VALUE attribute
         ! Function result
         integer(c_int) :: iret
      end function CFunction
   end interface
   public :: sub
contains
   subroutine sub()
      ! Local variables
      real(c_double), allocatable, target :: Output(:,:,:)
      real(c_double) :: p1
      real(c_double) :: p2
      real(c_double) :: p3
      real(c_double) :: p4
      integer :: n1
      integer :: n2
      integer :: n3
      integer(c_int) :: istat
      n1 = 2
      n2 = 2
      n3 = 2
      allocate( Output(n1,n2,n3), stat=istat )
      if ( istat /= 0 ) then
         ! error handling elided; error stop for this simple example
         error stop
      end if
      Output = 0.0_c_double
      p1 = 1.0_c_double
      p2 = 2.0_c_double
      p3 = 3.0_c_double
      p4 = 4.0_c_double
      istat = CFunction(p1, p2, p3, p4, c_loc(Output))
      print *, "In sub: Output = ", Output
      return
   end subroutine sub
end module m
program p
   use, intrinsic :: iso_fortran_env, only : compiler_version
   use m, only : sub
   print *, "Compiler Version: ", compiler_version()
   call sub()
   stop
end program p
Upon execution with Intel Fortran,
 Compiler Version:
 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on IA-32,
  Version 18.0.0.065 Beta Build 20170320
In CFunction:
p1 = 1.000000
p2 = 2.000000
p3 = 3.000000
p4 = 4.000000
output[0] set to 99.000000
 In sub: Output =  99.0000000000000 0.00000000000000
 0.00000000000000 0.00000000000000 0.00000000000000
