29348 Discussions
How to prevent the Heap memory from exhaust ?
Jack_S_
Hi all,
Sorry if this is a side topic compared to this forum main scope, but I hope couple of us will benefit from it :
What is the best practice (in Fortran-90) to prevent the heap memory from exhaust (in Linux) ? In general, what is the best practice ''memory model'' when coding an average code (in complexity and size) in Fortran-90, are there any special guidelines ? For instance, I have read that using multiple times a subroutine which allocates / deallocates local arrays can exhaust the memory. I currently experience heap exhaustion in my code and I'm not sure how to tackle it.
Thanks in advance for your comments,
Jack.
If you use ALLOCATABLE and not POINTER, you should not have any memory leaks. This is by design in the language. You could use the memory growth tracking feature of Intel Inspector XE to see where allocations are coming from and if you have any leaks due to POINTERs.
Best practice is to use ALLOCATABLE.
Jack_S_
Thank you Steve.
Jack.
