29426 Discussions
How to put a output file in a network path
carmenr1974
Hello Folks
I need to create a code in Intel Visual Fortran, that program generate an output file. I need to put that output file in a network path ex: \\\\server_name\\resource_shared
I will appreciate if you could provide me the commands in fortran to do this! please
Thank you in advance and regards
anthonyrichards
New Contributor III
Try the attached as a console program (enter your own //servername/diskname/ ).
It worked OK for me:
program networkfile
program networkfile
implicit none
character(256) filename, record
filename="//sstdfile01/optics/helloworld.txt"
open(unit=10, file=filename, form="formatted",status="unknown")
write(10,*) 'Hello World'
close(10)
read(10,'(a256)') record
close(10)
print *,trim(record)
pause
end program networkfile
Please note that, because it is accessing a network drive, there may be several seconds delay sometimes between writing and reading the file.
