How to put comments in data file ?
forcpp
Hi all,
I want to know how to put comment(s) in data file that should be ignored during read command. I read some where by putting hash in starting of a comment it can be done. But when I follow this procedure, I get error.
For example:
program file: test.f90
program test
implicit none
integer :: i
real(8) :: x
open(1,file='data.d')
do i = 1, 5, 1
read(1,*)x
print*,x
end do
end program test
Data file: data.d
1
# ignore me
2
3
4
5
Error: 1.00000000000000
At line 8 of file test.f90
Fortran runtime error: Bad real number in item 1 of list input
Thanx.
jimdempseyatthecove
Read file lineinto a character variable, test first chare for '#', if '#' cycle, if not perform internal read of character variable into real. (to do an internal read substitute the character variable for the i/o unit).
Jim Dempsey
forcpp
Jim Dempsey
Thanx Jim. It mean without internal read we can not ignore commented line in spite of we defined the variable type.
Thanks again for giving your valuable time.
jimdempseyatthecove
The other route to take is to place the comment on the same line
1 ! one potato
2 ! two carrots
3 ! three peas
Then let the read pull in the number and discard the remainder of the record.
When reading one (or fixed number of) variable(s) a comment can be anything following a field seperator
1one potato
2two carrots
3three peas
But you may want to generalize the input and permit expressions
1+2/3 cups milk
Or have your input file be pseudo language with variables
milk=1+2/3 cups
potato=1
carrots=2
peas=3
In the above "cups" is a volumetric scaling factor (oz, quarts, etc).
There are scripting languages that you can incorporate into your input routine. My preference is to roll my own.
Another technique I use is to make the input file in a form usable by the Fortran Preprocessor (or C Preprocessor). Edit that file but add to make file or solution a "compilation" through FPP
[cpp]! GRUN77.h
#include "GTOSS.inc"
! The above include file has
! #define LateStart nn
! #define AVRDBSnapshotInterval mm
! #define DELTAT tt
! ... and a whole bunch of additional code values
C When "compiling" for late start uncomment the following define
! #define LATE_START
#ifdef LATE_START
LateStart  1.0                 ! 1.0 TO REQUEST LATE START
AVRDBSnapshotInterval   360.0  ! AVRDB Snapshot Interval (seconds)
DELTAT                  0.05   ! DELTAT: REF PT
#else
! DELTAT                  0.01 ! DELTAT: REF PT
!AVRDBSnapshotInterval   360.0 ! AVRDB Snapshot Interval (seconds)
AVRDBSnapshotInterval   720.0  ! AVRDB Snapshot Interval (seconds)
#endif
[/cpp]
The FPP technique permits you to maintain a readable input file with comments, limited variables, and conditional compilation plus include files.
To compile
FPP -P -noC grun77.h grun77.dat
I use a batch file
! GRUN.BAT
FPP -P -noC GRUN%1.h GRUN%1.dat
And then issue
grun nn
where nn is the sequence number of the test data. You could use
! h2dat
FPP -P -noC %1.h %1.dat
Have fun
Jim Dempsey
forcpp
1 ! one potato
2 ! two carrots
3 ! three peas
1one potato
2two carrots
3three peas
1+2/3 cups milk
milk=1+2/3 cups
potato=1
carrots=2
peas=3
[cpp]! GRUN77.h
! #define DELTAT tt
#ifdef LATE_START
#else
#endif
[/cpp]
To compile
I use a batch file
! GRUN.BAT
And then issue
grun nn
! h2dat
Have fun
Jim Dempsey
Thanks again for the alternate suggestion.
