29359 Discussions
How to read .dat files with different filenames, please?
Zetian_R_
I am using fortran for coding. Now I am going to read more than 1000 data files separately, from the data file folder D\Datas\fortran
And the data filenames are like:
Gstep00001.dat  Gstep00002.dat  ... Gstep01230.dat
and the contents are like:
    -0.0004349421733      1.0583843781537
    -0.0004059937166      1.0583825316509
    -0.0003770452599      1.0583806851481
    -0.0003480968032      1.0583788386453
    -0.0003191483465      1.0583769921425
    -0.0002901998898      1.0583751456397
    -0.0002612514331      1.0583732991369
    -0.0002323029764      1.0583714526341
    -0.0002033545197      1.0583696061313
    -0.0001744060630      1.0583677596285
So how to accomplish this in fortran, please? Waiting for your help, thanks!
Sinserely
Ren
Arjen_Markus
I will assume that the problem you are facing is opening these 1000 files one by one without having to put these names into the program itself.
One way to do this is to use a so-called internal write statement: you write to a character string instead of a file. Here is a small example:
character(len=20) :: filename
do i = 1,1230
    write( filename, '(a,i5.5,a)' ) 'Gstep', i, '.dat'
    open( 10, file = filename )
    ... read and process the data ...
    close( 10 )
enddo
Note the format "i5.5" - it causes the program to insert 0's before the actual number, so that 111 is written as 00111.
I will leave the reading and processing of the actual data to you.
Arjen_Markus
do i = 1,1230
    close( 10 )
enddo
Zetian_R_
Thank you so much!
