29487 Discussions
How to read line with a blank character in the end.
Mikko_fortran_coder
Hello!
I try to modify my program to read lines that contain blank charaters (written with space) at the end of the line.
In the program i'm using the command line:
character*(*) line  !this is the character line to where we read
read (unit=11, '(A80)') line
So in the file (*.txt-file), the line is:
R=
The last character of that line is blank character (space).
Is there any way to find out that line is 3 characters long and the last character is blank?
Thanks!
Steve_Lionel
LEN_TRIM will tell you the length without trailing blanks. You can then compare the part of the string after that against blank.
Mikko_fortran_coder
Hello.
Thanks for your answer,
however, the problem is that Len_Trim would return value integer=2, since the last character of the line (in the text-file) is blank (or written with space) : 'R= ' .
So the question is, is there a possibility to recognize these blank characters from the end of the line? (so that the return integer value would be integer=3) ?
- Mikko
andrew_4619
line looks like a subroutine argument so in the caller is has some length (maybe 80 based on the read)
len(line) will give you that but after the read you will find line is fully padded with trailing spaces to the end irrespective of if there was a space or end of line after the equals. You will see a space in both cases! What are you trying to do?
Mikko_fortran_coder
andrw_4619 wrote:  "You will see a space in both cases! What are you trying to do?"
Well I try to explain this situation more precisely. The textfile from where the lines are read could contain line such as:
Rv =
Now there is a blank character in the end of that line (meaning written with space).
Basically i need to find a somekind of method to find out whether the line in the text-file is 'Rv = ' or Rv =' . So the blank character in the end of the line is the problem.
Mikko
Steve_Lionel
I would think that LEN_TRIM(line)+1 would do this, assuming there was room in the variable for at least one blank.  But I agree with @andrew_4619  that you're probably asking the wrong question.
mfinnis
New Contributor III
I'm not sure what the standard says about this and the state of the file afterwards but it seems to work ok with ifort
  block
      integer :: i_char,iostat,n_char
      do  i_char = 1,Min(Len(line),80)
          read(11,'(a1)',advance = 'no',iostat = iostat) line(i_char:i_char)
          if (iostat /= 0) exit
      end do
      if (iostat /= 0) then
          line(i_char:) = ' '
      else
! Oops          read(11,'(/)')
          read(11,'()')
      end if
      n_char = i_char - 1
  end block
line will be the same as if read as A80 and n_char will be the number of characters read including trailing spaces.
jimdempseyatthecove
You can read the file in Stream mode binary and parse the line breaks.
.OR.
Use the C interoperability to call a C/C++ function to read the lines. (Open the file on the C/C++ side too).
Jim Dempsey
Mikko_fortran_coder
I just started to modify the code, so that the file is opened and read in stream mode binary. I will use this method to solve the problem.
Mikko
mecej4
Here is another approach for you to consider: create a copy of your data file with all trailing blanks removed. Make your program process the copy, and note that the program can be simpler because it can assume that no input lines have trailing blanks.
Arjen_Markus
I have code like this:
! read_line_from_file --
!    Read one complete line as a string from a file
! Arguments:
!    lun         LU-number of the file to be read
!    text        Text string to be created/filled
!    eof         Whether end-of-file was reached or not
! Side effects:
!    Text string is properly initialised
subroutine read_line_from_file( lun, text, eof )
    integer, intent(in)              :: lun
    character(len=:), allocatable    :: text
    logical, intent(out)             :: eof
    integer, parameter               :: SEGMENT_LENGTH = 40
    character(len=SEGMENT_LENGTH)    :: segment
    integer                          :: reclen
    logical                          :: eor
    eof  = .false.
    text = ''
    ! Read the record in segments
    do
        read( lun, end = 180, eor = 170, fmt = '(a)', &
              size = reclen, advance='no') segment
        ! Not at the end yet, add to the string
        text = text // segment
    enddo
    ! End of record (end of file will give an empty text string)
170 continue
    text = text // segment(1:reclen)
    return
    ! End of file
180 continue
    text = ''
    eof = .true.
    return
    ! Errors are not handled explicitly ...
end subroutine read_line_from_file
The idea is to read chunks up to the end of the line and concatenate everyting. By using the "size = variablename" option you get exactly the size of the chunks that was read.
