29359 Discussions
How to recover fortran integration to visual studio?
dimdol10
I disabled the option of fortran integration to visual studio (fortran IDE) by mistake, thus, fortran projects are not able to be executed now.
How can I enable this again?
TimP
You can add Visual Studio integrations to ifort by repeating installation with the modify option, which should present a choice of detected VS versions.  If you didn't select the option to remove temporary files after installation, you will not need to repeat the unpacking phase of installation.
