How to reduce array
alexismor
Hi everybody,
I'm not sure if this is the right place to post this, but I'll try anyway. I'm trying to figure out what's the most efficient way to do this following problem:
I have a subroutine that has inputs A (which is an array) and "indexes" (which is a list of indices of data to be eliminated from the array A. I currently have a way to do this, except I find it quite clumsy. I'm quite new to fortran 90 and so I was wondering if there was a fancy way of doing this with all those new intrinsics such as MERGE and PACK.
Here's a specific example:
On input I have:
A=(10,11,22,33,44,55)
indexes=(2,5)
I then call reduce(A,indexes)
On output I want
A=(10,11,33,44)
Thanks!
Message Edited by alexismor on 06-23-2005 08:25 PM
TimP
LOGICAL MASK(SIZE(A))
MASK = .TRUE.
MASK(indexes(:SIZE(indexes)))= .FALSE.
A = PACK(A, MASK)
should do this.
The implementation in ifort isn't particularly efficient in run time.
alexismor
Thanks! I'll give it a try right away.
Alexis
alexismor
Hi Tim18,
I played around with your suggestion and it seems to work fine except for the fact that the matrix A still has the same size before and after the pack command. To get around this I used and intermediary array called B:
subroutine reduce(A,indexes)
implicit none
integer, allocatable, intent(inout) :: A(:)
integer, intent(in) :: indexes(:)
integer :: B(size(A)-size(indexes))
logical :: mask(size(A))
mask=.true.
mask(indexes)=.false.
B=pack(A,mask)
deallocate(A)
allocate(A(size(B)))
A=B
return
end subroutine reduce
Is this the only way?
Also, I was wondering why you specified the upper bound on the indexes array in the following line:
Isn't this the same as
MASK(indexes)= .FALSE. ?
Thanks for your help!
Alexis
TimP
Alexis,
As you can see, I am more used to the old-fashioned scheme of leaving an array allocated and taking care to specify the upper bound of the part which is in use. You are correct about my redundant use of SIZE(); it's just my habit of always specifying an upper bound. If you have a reason for taking the time to deallocate memory you don't need after PACKing, I have no problem with your suggestion, There was a thread on reallocation recently on comp.lang.fortran USEnet group which may be related.
alexismor
Thanks for the reply--you've been a great help.
Cheers,
Alexis
alexismor
One last question, I promise! Is there something equivalent to PACK for 2D arrays? Thank!
Steven_L_Intel1
No - PACK works on rank-1 arrays only.
