29653 Discussions
How to reset Fortran Build Environment (command line)
ozhou
I just installed the Visual Fortran. The default path for the command line is"C:\\ Windows \\ system32"
as defined by Windows Start --> Intel Fortran Software Development Tools -- > Fortran Build Environment.
I am thinking of doing the command line compilation in another place (e.g. C:\\ myproject). How do I reset the default path?
Thanks for helping me out.
You can right click on the shortcut, select Properties, and set "Start in". I usually drag a copy of this shortcut to my desktop for easy access.
