29640 Discussions
How to retrieve compilation options the code has benn compiled with at run-time
FlyingHermes
Is there a way to retrieve the compilation options a given fortran code has been compiled with.
In particular, I'm  interested in knowing if the code is being run in parallel using the "-coarray" option.
If so, some variables need to have the "codimension" attribute in their declaration.
For the time being, I added these lines in my Make.inc file which is included in my Makefile:
PARALLEL=on
ifeq ($(PARALLEL),on)
      PARALLEL_FLAG= -coarray -coarray-num-images=2 -DPARALLEL
else
      PARALLEL_FLAG=
endif
FFLAGS= ... (OTHER COMPILATION OPTIONS) ... $(PARALLEL_FLAG) -fpp
The source code is being preprocessed (option "-fpp") and the "PARALLEL" keyword is defined (option "-DPARALLEL")
Then, in my source code, I'm using the following preprocessing conditional structure:
[fortran]
#IFDEF PARALLEL
  class(Mesh_Type) ,codimension
  • ,intent(inout)  ::      This
    #ELSE
      class(Mesh_Type)                 ,intent(inout)  ::      This
    #ENDIF
    [/fortran]
  • Is there a better way to do it?
    Sorry, no.
    jimdempseyatthecove
    If you are using FPP you could
    #ifdef PARALLEL
    #define _CODIMENSION_   ,codimension
  • #else
    #endif
    class(Mesh_Type) _CODIMENSION_ ,intent(inout)  ::      This
    A lot cleaner than using #if... and/or !DEC$ IF...
    Jim Dempsey
    FlyingHermes
    Yes, it is indeed much cleaner !!!
    Thanks Jim
