29642 Discussions
How to turn off Load pair Optimization or SWP?
george_her
ldfp instruction could load two contiguous single or double precision valuse from memory in one move,
DoesICC9.0 provideany option to turn this optimization off?
In the other hand, I could not find any option to turn off SWP
Software Pipelining in ICC9.0 .
Message Edited by George_Her on 09-22-2005 01:50 AM
TimP
icc equivalent of ifort directive
#pragma noswp !DIR$ NOSWP
Look them up in the docs. If you want further help with C, use the C++ branch of the forum.
When the compiler decides to use load-pair, it usually makes a very large improvement in performance, much more than the schedule would indicate. You can prevent it by using -O1, or the pragma.
Searching the documents is cumbersome. icc/ifort 9.0 documentation expects you to copy the html files over to Windows. In the 8.1 documents, pragma noswp is covered in Compiler User's Guide > Vol II: Optimizing Applications > Optimization support features > Compiler Directives > Pipelining for Itanium
Message Edited by tim18 on 09-22-2005 09:19 AM
