29648 Discussions
How to use Array Visualizer as component
rahzan
No separate run-time license is required. The user would install the Array Viewer demo/redistributables kit to get the necessary DLLs and controls. Note that this will not permit use of the controls in a "design" environment (can't add the control to a VB form, for example.)
Any of the AV applications could be "distributed" this way.
Steve
rahzan
Is there sample on how to use the thing?
Tim
Intel_C_Intel
You can find many examples at C:ProgramArrayVisualizerSAMPLESFORTRAN (or C:Program Files...).
I have used VECTOR3C, with own modifications, successfully. I don't remember if it was optional to copy the sample files, or not, when I installed Array Visualizer.
Sabalan.
hanglai123
Hello there:
Do you have up-to-date Intel fortran Array visualizer examples,incuding 3-D axis label and scale labels?
[email protected]
