How to use resedit for intel fortran
marigomen__ralph
Can anyone help me out on how to include the resource file generated by resedit into intel visual fortran?
I couldn't seem to make it work..
I tried making a dialog in resedit and then added the .rc and .h file in my solution in visual studio.
I then added a custom build setup for resource.h using steve's guide below:
Steve Lionel (Intel) wrote:
ResEdit should generate both a .rc and a .h. You will need to add both of those to your Fortran project and add a custom build step for the .rc:
  1. Add Resource.h to your project using File>Add Existing Item....
  2. Select the Resource.h file in the Solution View and the select View>Property Pages from the main menu bar.
  3. Set the Command Line option to use the deftofd tool by entering:
    deftofd resource.h resource.fd
  4. Set the Description option to Generating Fortran include file...
  5. Set the Outputs option to resource.fd.
  6. Click OK.
Problem is i couldn't compile my program successfuly. I always get the following error:
Error 1 fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt LINK
It would be nice if someone could post a complete guide for beginners in using resedit in intel visual fortran..
Thanks in advance. ^^
andrew_4619
That doesn't sound to me like  a resource/resedit issue. Try doing a 'clean' and then a full 'rebuild' it sounds like an obkect file is corrupt.
As a matter of interest I assume the fortra fd must be could or else you would have had comple errors. Did the resource file compile OK also?
marigomen__ralph
yeah.. it did compile OK.
I attached my project file below for reference.
andrew_4619
I downloaded and built your project, other than adding the include file path (C:\Program Files\Microsoft SDKs\Windows\v7.0\Include) for windows.h as it was not default in my environment it built OK with no problems and it runs OK also.
I can't see any problem  did you do a clean? Or perhaps download your project into a new folder and build that to have a clean start. I think you may have some damaged files perhaps?
marigomen__ralph
Have tried doing a clean build and trying to create a new project but I'm still getting the same error..
I'm guessing something's wrong with my configuration in visual studio....
andrew_4619
I am not perhaps the right person to help further on this is there any more info details of the specifics of the error, do a full build and post the build log perhaps?
