How to use the F10 key?
dboggs
I have a group of programs written in DOS F77 that allowed the user to respond to various prompts, menus, etc. using a variety of keys, including F1 - F10. These programs must be upgraded. Trapping the extended key scan codes for the function keys is easy, so in general this is no problem, But, the F10 key is special. My program sees F10 and continues accordingly, but Windows also traps it and attempts to open the File object on the window's menu. Then, further input of keys is blocked until the user completes the menu action--something which of course he doesn't want to do.
A simple <escape> keypress would close the menu and allow the program to continue. But the client WANTS to use the F10 key and he doesn't WANT to follow with <esc> every time. I thought it should be easy to have my program simulate the <esc> keypress, but I can't get anything to work. I have tried using functions like:
     I4 = SYSTEM (CHAR(27))
     I4 = SYSTEMQQ (CHAR(27)
These work sometimes, but not consistently. Then I tried
    I4 = SYSTEM (SendEscape.vbs) where SendEscape.wsh is a singel-line script file "wsecho chr(27)".
This seems to work, but unfortunately the screen flashes briefly while the script runs. Would be nice to turn this off, but I don't know how.
Any ideas?
Paul_Curtis
Valued Contributor I
F10 and similar keys can be trapped by inserting a hook process; I have posted sample code for this before.
GVautier
New Contributor III
Hello
Do you upgrade your programs to console or windowed applications?
dboggs
Not sure what the relevancy of your inquiry is, but for what it's worth I am upgrading old F77 programs to Quickwin applications. I think the issue with the F10 key is independent of the type. If it's not I would like to know some details.
GVautier
New Contributor III
Have you tested the passdirkeysqq function ?
dboggs
Yes, I am using passdirkeysqq. Does F10 trapping work for you?
Also: the shift-tab key does not work--it is intercepted by Windows, just like F10. It turns out that not being able to program a response to shift-tab causes even more grief than F10.
GVautier
New Contributor III
I uesed Quickwin long time ago and I don't remember if I had problems with f10 key. With a classic windowed application, I intercept the  WM_SYSCOMMAND message with wparam=SC_KEYMENU and lparam=0 to intercept f10 key.
