29390 Discussions
How to use write command to put data into a character* (similar to sprintf in C)
acobulareddy
The following program is working fine in UNIX where as printing ****** in windows. Please let me know what is wrong with write(STRING1,I9) 12.35 statement
program fortrantest
CHARACTER*9 CLOCK1
write (CLOCK1,'(I9)')12.35
write(*,*)"REDDYO - ",CLOCK1
end program fortrantest
Chandra.
jimdempseyatthecove
Quoting - acobulareddy
program fortrantest
CHARACTER*9 CLOCK1
Chandra.
You have an argument mis-match between your format string (I9) = integer width of 9, and 12.35 which is either real(4) or real(8). Make a change to make the two consistent (both integer or both float).
Jim Dempsey
Luis2
program main
CHARACTER*9 CLOCK1
real x
x=12.35
write (CLOCK1,'(f5.2)') x
write(*,*) "REDDYO - ", CLOCK1
end program
jparsly
Others have pointed out that there is a mismatch between your data and your format. Since this is an error, compilers are free torespond however they like. I've seen three distinct behaviors from various compilers for this particular error:
1. Crap out with error message
2.Truncate the real to an integer, print the integer, and keep going
3. Act as if the real variable was equivalenced to an integer, and attempt to print the integer version of what is in the memory location. This is likely to get you *****'s because the integer version is often a very large number. I suspect in these cases this is an "argument association" type of equivalence where a call to the run-time library for formatted output is passing the real variable's address to a routine that is expecting an integer.
Intel Fortran does #3 by default. To have it give an error message, add the option /check:fornat
