How to watch a variable
aj10599
Does anyone knowan easyway to "watch" a variable? (i.e. detect when it changes)
using the debbugger?
kooka
you mut place a breakpoint in your code, and then in debug mode, place the mouse icon on the variable you want to know, instead you can select it and press the quikwatch icon
This is available as long as you are not using the bundled Visual Studio 2005 Premier Partner Edition. When you are in the program unit with the variable, select Debug > New Breakpoint > New Data Breakpoint. Enter the name of the variable. Leave the "language" as C.
I will comment that this often does not work.
aj10599
Is there a way to get the program to break if the variable changes? (This is not the
same as conditional breakpoint which assumes a location)
aj10599
You are right about "that this often does not work". It was asking for "address" so I
did a LOC(varname) in the itermediate window and put a number in for address (very awkward.)This worked for a while; however,when I reinstalled VS5 (PPE.exe) the"New Data Breakpoint" does not even appear as a selection when the debugger breaks.Is there a simple way to get the debugger to stop when it detects a change in a variable?
As mentioned in the Release Notes, data breakpoints are not available when you're using VSPPE. This requires a "retail" version of VS. This was not intentional and we are working with Microsoft to see if we can resolve it in the future (it requires Microsoft's assistance.)
Data breakpoints in Visual Studio have never worked well in my experience, going back to VS97. You ought to be able to just type a variable name there - sometimes it works, sometimes it doesn't. Watching an address is somewhat more reliable, if that's available to you.
