29642 Discussions
I am getting a compilation error when running this code
nikesh
Hello all
I am running a Fortran code using LS-DYNA object executable file but get an error.
Error like as when I am writing any line of the code it is running the code successfully
ex: write(*,*) 'Line 813',sigav
But when the same line is commented the code is not running successfully.
ex: !write(*,*) 'Line 813',sigav
This is a strange error that comes in my FORTRAN routine. Have anyone stuck with this above error? if yes then please share your valuable suggestion.
some part of my routine is:-
dsigv = matmul(celas,depsp)
sigav = sigav + dsigv
call eqstrs(idele,nstrc, sigav, sige1)
call eqstrn(nstrc, depsp, sige1, sigav, depse)
epse1 = epse1 + depse
dummy_depse = depse
endif
stncm = (1.d0 - inits)*ratio*stncm
your suggestion will be highly appreciated
regard
nikesh
Arjen_Markus
This is often a sign of array bound violations or a mismatch in actual and dummy arguments to routines. The first step is to turn on all the warnings and runtime checks via the various compiler options. You can ask the compiler to automatically generate modules for you, so that routines that are defined outside modules still can be checked.
One caveat: if you use assume-size arrays (real :: a(*) and the like), the check on array bounds is less than effective. I have been bitten by that very recently (I got lazy because I always or almost always use modules to contain my routines ;)).
Arjen_Markus
andrew_4619
Any answer will be guesswork. You do not identify what the error actually is. Compile error? Fortran run time error? LS-DYNA solver error? Bad results?
nikesh
Thanks  @Arjen_Markus  for your valuable suggestion
