29333 Discussions
I got the message error LINK: fatal error LNK1181 cannot open input file
Zang_Lee
I have Parallel Studio XE 2013 with Visual Studio 2013. .
  1. I start a new IVF Project (static Lbrary)
  2. In VS2013, I add a new  win32 console application to the IVF Project
  3. I set the fortran function dependent to the main cpp
Please see below
#include "stdafx.h"
#include <iostream>
using namespace std;
extern "C"
  void __cdecl FR1(int *a, int *b);
  int __cdecl FF1(int *c);
int main()
 int n = 10;
 int nSq;
 int nCube;
 FR1(&n, &nSq);
 cout << "The square is:" << nSq << endl;
 nCube = FF1(&n);
 cout << "The cube is:" << nCube << endl;
 getchar();
 return 0;
// fortran f90
subroutine FR1(N,M)
!DEC$ ATTRIBUTES DLLEXPORT :: FR1
 M = N*N
return
end
integer function FF1(N)
!DEC$ ATTRIBUTES DLLEXPORT :: FF1
FF1 = N*N*N
    return
    end
I am trying to call  a fortran function f90 from C++, but i got two time the error message  LNK2019
error LNK2019: unresolved external symbol referenced "_FR1" in function _main
error LNK2019: unresolved external symbol referenced "_FF1" in function _main
 With Dumpbin /symbols I got the error message LINK: fatal error LNK1181 cannot open input file
C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC> cd c:\visual studio 2013
\Projekt2\Fortfunc\Debug
c:\visual studio 2013\Projekt2\Fortfunc\Debug>dumpbin/symbols Fortfunc.dll
Microsoft (R) COFF/PE Dumper Version 12.00.21005.1
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file Fortfunc.dll
LINK : fatal error LNK1181: Eingabedatei "Fortfunc.dll" kann nicht geöffnet werden.
Thanks in Advance
The article mecej4 links to explains how to do this in newer VS versions - keep reading. But for your problem, the following note in that article is also important:
NOTE: In Microsoft Visual Studio 2010 and later, a C++ project will not link in a non-C++ dependent project library. If you are using a C/C++ main program with a Fortran static or dynamic library as a dependent project, you must explicitly provide the path to the Fortran library, (the .lib export library in the case of a DLL project), in the C/C++ project's Linker > Additional Dependencies property, or as a "source file" in the project.
Is there a particular reason you're building the Fortran code as a DLL? Would a static library do?
mecej4
In more recent versions of Visual Studio, there are some impediments (set up by Microsoft?) to building projects in which the user wishes to mix sources in C/C++ and another language. See https://software.intel.com/en-us/articles/configuring-visual-studio-for-mixed-language-applications , where the procedure for accomplishing your goals is explained. Alternatively, you can build your sample easily at the command line. Compile the Fortran routine into a .OBJ file, and then do icl cmain.cpp fsub.obj .
Zang_Lee
I can't find the VC++-Directories from Tools->Options->Projects and Solutions ..it is outdated. Can you give me some Details about second Option of your alternativ ? Where and How can I do icl cmain.cpp fsub.obj ? please
mecej4
I assumed that you have either the Microsoft VC or Intel C compiler installed.
You open an Intel Fortran command window (from the Start Menu or a suitable shortcut), and type the commands there. If you already have fsub.fxx compiled, the command that I gave (use cl instead of icl, if you do not have Intel C) will work if you have placed fsub.obj in the same directory as cmain.cpp.
Zang_Lee
Thank you Steve, I provide the path to the Fortran library as a source file in the Project and it works.
Zang_Lee
Thank you mecej4 for the article and thank you for Details about the second Option
