IA32 or EM64
chang1
Hi, Steve,
I just installed the latest IVF9.1 (extension -025)and the VS2005. Since I have to install both IA32 and EM 64for integrating the compilet to VS2005, how do I know the one integrated is the EM64 (which is what I want), not the IA32? My operation system is Windows XP(64 version).
regards
Chang
The compiler you use is determined by the target platform you select. If you select a target of x64, you get the EM64T compiler.
chang1
Steve,
Thank you. But how do I select the target platform when I install the compiler? I did not see an option.
regards
Chang
You don't select it when you install - by default, you get both the IA-32 and EM64T compiler on install (if you have a suitable version of Visual Studio or the PSDK.)
See the Building Applications manual section on VS projects for details on how to select the target platform. It isn't obvious.
