29653 Discussions
ICE + ELEMENTAL + allocatable-length character
John4
Valued Contributor I
In the code below, I get an ICE. that seems to be caused by the combination of ELEMENTAL keyword (in the function some_verification) and allocatable-length character variable string. By removing the ELEMENTAL keyword or changing the definition of string to fixed-length character, the ICE goes away. So, besides the fact that an ICE usually implies compiler bug, is the code invalid?
[fortran]module some_module
    implicit none
    private
    save
contains
    function some_function(arg) result(status)
        logical :: status
        character(*), intent(IN) :: arg
        integer :: i
        character(:), allocatable :: string
    continue
        status = .FALSE.
        string = TRIM(arg)
        i = LEN_TRIM(string) / 2
        i = MERGE(0, i, some_verification(ADJUSTL(string(:i-1)), 'PARAMETER'))
        status = .TRUE.
    end function
    elemental function some_verification(string, val) result(status)
        logical :: status
        character(*), intent(IN) :: string, val
        integer :: lval
    continue
        status = .FALSE.
    end function
end module some_module
[/fortran]
This issue has been fixed in the compiler sources. The fix should appear in the next major release, planned for late this year.
Paul_Curtis
The character variable string is not an array, and hence is not properly allocatable; only arrays are allocatable. Also, the attempt at implicit allocation simply by assigning string as the TRIM() of another character variable is poor practice.
IanH
Fortran 2003 introduced allocatable scalars, deferred length character variables and implicit allocation on assignment. What's good and bad practice is a often a matter of taste, but use of these three features in concert strikes me as being an eminently reasonable way to do string handling in the modern form of the language.
TimP
Implicit allocation is not enabled by default in ifort. If you intend to use it, you must set /assume:realloc_lhs
Ideally, you would get a clearer error message about this, if that is among your problems.
John4
@Paul Curtis: The Fortran 2003 standard added allocatable-length characters to the language (i.e., the LEN part of the character declaration is what's allocatable). And although this discussion is not about coding practices, I agree with you that for assignment to fixed-length characters, ADJUSTL is a better option than TRIM.
@tim18: In IVF, Implicit allocation for allocatable-length character variables (and derived types components, I guess) is independent of the /assume:realloc_lhs flag.
I just wanted to report the ICE/bug, since the forum search didn't return anything related... And also, I wanted to know of any constraints in regards to ELEMENTAL procedures and allocatable-length character variables (but I guess I'll just ask somewhere else about this).
I've found the same sort of ICE throughout some of my code, in previous versions of IVF (especially with allocatable-length character results), but, until now, I could never find a short way to reproduce it (so I usually just changed the ELEMENTAL keyword to PURE).
John is correct - the /assume:realloc_lhs option is not required for deferred-length character variables. I can reproduce the ICE and will escalate it - thanks for the nice example. I was able to simplify it a bit further to eliminate the MERGE, but the ADJUSTL call is required. Issue ID is DPD200154603.
