29382 Discussions
ICE in ifx with array slice of deferred length character variable
martinmath
The following code gives an ICE in ifx 2023.0.0 20221201.
It seems to be essential that variable x is polymorphic.
Remark: this bug has been mentioned on fortran-lang.discourse.group, but I could not find it here, nor any short reproducer.
program string_slice
type :: t
   character(len=:), allocatable :: cs
end type t
class(t), allocatable :: x
allocate(t :: x)
x%cs = 'abcdef123456'
print *, first(x%cs(7:))
contains
function first(cs) result(d)
   character(len=1) :: d
   character(len=*), intent(in) :: cs
   d = cs(1:1)
end function first
end program string_slice
martinmath
I have now encountered a very similar problem. No ICE, but the produced code gives a wrong result.
The result of a concatenation 'x%cs // y%cs(lower:upper)' is computed (x and y of type(t) from above), but with the wrong section from y%cs. In fact, the section y%cs(1:upper-lower+1) is appended. The provided lower bound "lower" is ignored, the length of the section is correct.
Unfortunately I do not yet have a small reproducer for this problem. When I touch the routine where the y%cs character value is actually assigned, I run into the ICE mentioned above. The hopefully this is related.
Barbara_P_Intel
Good news! The ICE is gone in an internal version of ifx. The version with the fix is planned for release in the spring.
