29654 Discussions
ICE / invalid code with extended type
jahern
I believe I've found two problems when compiling this code:
[fortran]MODULE ColorMod IMPLICIT NONE TYPE, ABSTRACT :: EnumVal INTEGER :: val = 0 END TYPE EnumVal TYPE, EXTENDS(EnumVal) :: ColorEnum END TYPE TYPE :: ColorEnumList TYPE(ColorEnum) :: RED = ColorEnum(4) END TYPE ColorEnumList TYPE(ColorEnumList), PARAMETER :: COLORS1 = ColorEnumList() END MODULE ColorMod PROGRAM test USE ColorMod IMPLICIT NONE !TYPE(ColorEnumList), PARAMETER :: COLORS2 = ColorEnumList() ! ICE if uncommented WRITE(*,*) COLORS1%RED%val ! should print "4", not "1" !WRITE(*,*) COLORS2%RED%val ! should print "4" END PROGRAM test[/fortran] There appear to be 2 bugs. The output of the above is incorrect, printing "1" instead of "4". But also, the following ICE occurs if the statements in the program are uncommented:
Compiling with Intel Visual Fortran Compiler XE 12.1.3.300 [IA-32] ...
fortcom: Fatal: There has been an internal compiler error (C0000005).
I'm not sure whether these two problems are related or not. Let me know what you think.
Jared
Anonymous66
Valued Contributor I
Thank you for reporting these errors. I have escalated them both to the developers.
The issue number for the Internal Compiler Error is DPD200179526.
The issue number for errorcausingbad results is DPD200179518.
I will post an updates I receive on either of these issues to this thread.
Annalee
Intel Developer Support
Anonymous66
We are planning to include a fix for DPD200179518 in a future release which is currently scheduled for later this year.
Annalee
jahern
Thanks, Annalee. Please let me know if there is a plan for the other issue.
Anonymous66
The others issue is beinginvestigated by the developers. No plans have been made yet.
Anonymous66
We areplanning to include a fix for DPD200179526 in the same future release.
Annalee
Anonymous66
This is issue has been fixed in Intel® Visual Fortran Composer XE for Windows* 2013 which is now available at the Intel® Registration Center. Regards, Annalee Intel Developer Support * Other names and brands may be claimed as the property of others.
