ICE when compiling large F77 file
Ben3
I have a large (~2000 lines) F77 subroutine that I'm trying to compile. However, I get an ICE unless I completely turn off optimisation (-O0). I've been attempting to trace the source of the problem by commenting out sections, but it appears that it's a product of the sheer number of optimisations that the compiler is able to do (there's lots of vectorisation going on). This is the error:
[plain]bmenadue@weyl ~/bmenadue/Code/old/Align/vOverImpCoolSU3>ifort -extend-source -O2 -convert big_endian -c lotsaLoops.f
0_13171
lotsaLoops.f(6): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for lotsaLoops.f (code 1)[/plain]
I originally commented out everything, and then piece by piece by uncomment sections until I got the ICE, but by commenting statements above the (what I thought was the) source of the error made the ICE go away (less optimisable statements), until I uncommented more lines below the error, when it reappeared (sufficient optimisations to trigger the error).
My ifort version:
[plain]bmenadue@weyl ~>ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.3.174 Build 20110309
Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY[/plain]
I've been told that it successfully compiled using ifort version 11.0.074, but I don't this old version to test it.
I've attached the offending f77 file, along with the included .h file, if anyone is game to have a look - ignore the HPF directives, it's old code. Otherwise, I'm not sure how to proceed.
Ben
Kevin_D_Intel
Thank you for the post, Ben. I confirmed the internal error and that the source compiles and vectorizes many loops/blocks with the 11.0.074 release. It appearsthetroubles with the code began in 11.1 wherecompilation triggers awarning that an internal resource was exceeded and the optimization level was reduced internally.
I reported this to Development but have not found any other work around to compiling with -O0. I will update the thread if Development finds any other work around.
(Internal tracking id: DPD200172621)
(Resolution Update on 5/20/2012): This defect is fixed in the Intel Fortran Composer XE 2011 Update 4 (2011.1.4.319 - Linux)
Ben3
Thanks Kevin.
It appears to compile fine (even with optimisations) with the latest Windows compiler, but that doesn't help me much as my compute machine is Linux.
Ben
Kevin_D_Intel
Ben, please pardon the delayed update, this issuewas fixed in the earlier Intel Fortran Composer XE 2011 Update 4 (2011.1.4.319 - Linux). Newer updates are available at this time.
