29653 Discussions
ICE when using a type defined by an allocatable array and a procedure function that has a defined type as a result
kostas85
Hello all,
The following code produces ice and there are three cases that compilation won't produce ice :
module mytypes
type mytype
real(kind(0.d0)) :: a
end type mytype
type mytype1
real(kind(0.d0)), dimension(:), allocatable :: a ! fixing the dimension won't produce ice
procedure(fun), pointer, nopass :: proc
end type mytype1
contains
type(mytype) function fun(a) result(res) ! declaring the function as real(kind(0.d0)) or changing the function to a subroutine
implicit none ! won't produce ice
real(kind(0.d0)), intent(in) :: a
res%a=a**2
end function fun
end module mytypes
program check_ice
use mytypes
implicit none
type(mytype1) :: mt
mt%proc => fun
end program check_ice
Running the program I get:
g1@G1:~/Programming/checks$ ifort check_ice.F90
check_ice.F90(22): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for check_ice.F90 (code 1)
Changing the module as explained above, say :
1 . Fixing the dimension of array " a " doesn't produce ice
module mytypes
type mytype
end type mytype
type mytype1
real(kind(0.d0)), dimension(3) :: a ! <-- This changed
end type mytype1
contains
implicit none
res%a=a**2
end function fun
end module mytypes
program check_ice
use mytypes
implicit none
type(mytype1) :: mt
mt%proc => fun
2. Using an implicit type for the function result doesn't produce ice
module mytypes
type mytype
end type mytype
type mytype1
end type mytype1
contains
real(kind(0.d0)) function fun(a) result(res) ! <-- This changed
implicit none
res=a**2
end function fun
end module mytypes
program check_ice
use mytypes
implicit none
type(mytype1) :: mt
mt%proc => fun
3. The procedure fun is a subroutine and not a function :
module mytypes
type mytype
end type mytype
type mytype1
end type mytype1
contains
subroutine fun(a,res) ! <-- This changed
implicit none
type(mytype), intent(out) :: res
res%a=a**2
end subroutine fun
end module mytypes
program check_ice
use mytypes
implicit none
type(mytype1) :: mt
mt%proc => fun
Check it. Thank you.
Note ::
g1@G1:~/Programming/checks$ ifort -v
Version 12.0.0
Xiaoping_D_Intel
Thanks for reporting the compiler error. I have submitted a bug report on it.
Xiaoping Duan
Intel Customer Support
