ICE with PDT
Espen_M_
MODULE test
 IMPLICIT NONE
 PUBLIC
 INTEGER, PARAMETER, DIMENSION(6), PRIVATE :: kind_params = [0,1,3,7,9,14]
 TYPE :: dt(kind)
  INTEGER, KIND :: kind
  REAL,DIMENSION(kind_params(kind))  :: comps
 END TYPE dt
END MODULE test
The above code is a stripped down example of something I'm trying to compile that generates an internal compiler error due to the parameter array kind_params being used in the dimension specification of comps.
Thanks - escalated as issue DPD200367384.
Espen_M_
You're welcome :)
This will be fixed in version 16, to be released later this year. The fix isn't in the current beta and may not make the first beta update.
