29386 Discussions
ICE with locals declared in a block construct (IFX)
Andrew_Smith
Valued Contributor I
subroutine foo()
   block
      real a, b
   end block
end
xfortcom: Fatal: There has been an internal compiler error (C0000005).
ifx: error #10298: problem during post processing of parallel object compilation
Windows 10 with VS2022, oneAPI 2023.1
Barbara_P_Intel
I can't duplicate this ICE on Windows or Linux with ifx 2023.1.0.
What compiler options are you using?
>ifx -what -c foo.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2023.1.0 Build 20230320
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
 Intel(R) Fortran 23.0-1474.2
 On Windows I ran in a oneAPI command window.
Andrew_Smith
It is a debug config for 64 bit. Compiles OK in release config.
All options:
/nologo /debug:full /MP /Od /fpp /I"..\IMSL\emt64" /I"D:\Dev\r23.1.0\rxsstaticscalculator\MSXMLInterface\x64\Debug" /I"D:\Dev\r23.1.0\rxsstaticscalculator\Utilities\x64\Debug" /I"D:\Dev\r23.1.0\rxsstaticscalculator\DifferentialMaths\x64\Debug" /I"D:\Dev\r23.1.0\rxsstaticscalculator\DataPackage\x64\Debug" /I"D:\Dev\r23.1.0\rxsstaticscalculator\MathsConstants\x64\Debug" /DINITNAN /DDEBUGV /Dx64 /DenhancedChecking /Qopenmp /standard-semantics /stand:f18 /warn:declarations /warn:unused /warn:interfaces /Qinit:snan /Qinit:arrays /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\\vc170.pdb" /traceback /check:bounds /check:shape /check:uninit /check:format /check:output_conversion /check:stack /libs:dll /threads /dbglibs /Qmkl:parallel /c
Barbara_P_Intel
Thank you! It's the /Qinit:snan that is causing the ICE on both Windows and Linux. Remove that as a workaround.
I tried an early version of the compiler that is planned for release near the end of 2023. I did not get an ICE on Linux.
Mark_Lewy
Aside (?): BLOCK constructs seem to be a bit flaky with IFX 2023.1.  I've reported one example to support (05854745), which should be fixed in 2023.2.  I worked around it by changing the BLOCK construct to a DO construct (with EXIT before END DO), but I didn't have any declared variables in the BLOCK.
hakostra1
New Contributor II
I had a very similar error, but with integers and not reals in the BLOCK:
MODULE pointers_mod
    IMPLICIT NONE(type, external)
CONTAINS
    SUBROUTINE init_pointers()
        BLOCK
            INTEGER :: igrid
            INTEGER :: nsize3d
            CONTINUE
        END BLOCK
    END SUBROUTINE init_pointers
END MODULE pointers_mod
When compiled with "ifx -V -O0 -g -init=huge -c pointers_mod.F90" I get:
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2023.2.0 Build 20230721
 Intel(R) Fortran 23.0-1769.01
 #0 0x0000000002228e97 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x2228e97)
 #1 0x0000000002228fc0 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x2228fc0)
 #2 0x00007fe661242520 (/lib/x86_64-linux-gnu/libc.so.6+0x42520)
 #3 0x0000000002e01eb8 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x2e01eb8)
 #4 0x00000000031eb4c3 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x31eb4c3)
 #5 0x00000000031ebf18 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x31ebf18)
 #6 0x000000000311529d (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x311529d)
 #7 0x0000000002555100 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x2555100)
 #8 0x000000000216676b (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x216676b)
 #9 0x0000000002165047 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x2165047)
#10 0x0000000002111a78 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x2111a78)
#11 0x00000000022e13ce (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x22e13ce)
#12 0x00007fe661229d90 __libc_start_call_main libc_start_call_main.h:58
#13 0x00007fe661229e40 call_init libc-start.c:128
#14 0x00007fe661229e40 __libc_start_main libc-start.c:379
#15 0x0000000001f51aa9 (/opt/intel/oneapi/compiler/2023.2.1/linux/bin-llvm/xfortcom+0x1f51aa9)
/tmp/ifx1705834558GvM5l3/ifxqKA9WC.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for pointers_mod.F90 (code 3)
The error happens at all optimization levels, but only when "-init=huge" is present. If I remove one of the INTEGER's in the BLOCK construct the error vanish (i.e. it seems necessary to have more than one integer in there for the error to appear).
hakostra1
New Contributor II
Same error with integers in a block:
MODULE pointers_mod
CONTAINS
        BLOCK
            INTEGER :: igrid
            INTEGER :: nsize3d
            CONTINUE
        END BLOCK
With "ifx -V -O0 -g -init=huge -c pointers_mod.F90" I get:
Barbara_P_Intel
@hakostra1, your reproducer also works fine in the version of ifx destined to be released later this year in Q4.
Barbara_P_Intel
The version of ifx that was released this week has the fix for the ICE you reported. Please give it a try!
