ICE with output argument
Daniel_Dopico
This code throws an ICE in IFX and IFORT. Some versions of the compilers have also problems with a subroutine and intent(out) argument.
PROGRAM MAIN
IMPLICIT NONE
TYPE:: base_type
INTEGER:: i=0
END TYPE base_type
CLASS(base_type),POINTER:: e
REAL(8),ALLOCATABLE,DIMENSION(:,:)::f
f=f_test(e)
CONTAINS
FUNCTION f_test(e) RESULT(o)
IMPLICIT NONE
CLASS(base_type),POINTER::e
REAL(8),DIMENSION(3,e%i):: o
o=0.d0
END FUNCTION f_test
END PROGRAM MAIN
Daniel_Dopico
I got confirmation with some colleagues and filled a support request on this ICE.
Devorah_H_Intel
Thank you for reporting this to us. I have escalated this to compiler engineering for a fix.
