29649 Discussions
ICE with parameterized derived type as function output
WileyOne
Compiler: ifx (IFX) 2025.2.0
OS: Rocky Linux 8.10 (Green Obsidian)
I originally found this issue on 2024.2.0 and verified that it is still crashing with the latest compiler version.
module Ice5623_Example
    type :: SomeSystem(nStates)
        integer, len :: nStates
    end type
    type :: SomeClass
        type(SomeSystem(:)), allocatable :: model
    end type
    contains
    function constructor(nStates) result(this)
        integer                   :: nStates
        type(SomeSystem(nStates)) :: this
    end function
    subroutine configure(this, integer1, integer2)
        type(SomeClass) :: this
        integer         :: integer1, integer2
        this%model = constructor(integer1*integer2)
    end subroutine
end module
This code produces the following error:
Ron_Green
A compiler should never ICE.   But in this case at least it did emit a warning message to alert us that the code was invalid:
Ice5623_Example.f90(13): warning #6178: The return value of this FUNCTION has not been defined.   [THIS]
After which the compiler is still attempting to compile invalid code and hits the ICE.  This is because WARNINGS do not halt the compilation process.  For this case it's obviously a mistake.
It is interesting to see how  the NAG compiler handles this.  Notice that nagfor emits a warning for the result not being set, continues to compile but instead of getting an Internal Compiler Error it emits a final ERROR where that function is referenced.  The error message is a bit cryptic.
nagfor Ice5623_Example.f90
NAG Fortran Compiler Release 7.2(Shin-Urayasu) Build 7203
Warning: Ice5623_Example.f90, line 16: Result THIS of function CONSTRUCTOR has not been assigned a value
[NAG Fortran Compiler normal termination, 1 warning]
Ice5623_Example.f90: In function ‘ice5623_example_MP_configure’:
Ice5623_Example.f90:22:10: error: invalid type argument of unary ‘*’ (have ‘__NAGf90_LPDT_Pointer’)
   22 |         this%model = constructor(integer1*integer2)
We do not want a compiler to ICE even though the code is obviously invalid and reported with warnings as invalid.  I will write up a bug report but obviously at very low priority as the code is invalid and an appropriate and understandable warning was emitted.  Thank you for sending this to us.  I will post the bug ID shortly.
Ron_Green
I want to open a discussion with my team about this code.  Should the lack of RESULT setting be an ERROR level event instead of a WARNING level?  I can envision arguments for and against making it an ERROR level.  We'll discuss this at a future team meeting.
WileyOne
Thank you for looking at this, @Ron_Green. Our team has no need for this operation, so it's not urgent to us; I just wanted to be a responsible citizen and report the crash.
A minor change to the example shows that the warning and ICE are unrelated. The following still produces the crash:
        integer :: ii
    end type
    type :: SomeClass
    end type
    contains
        integer                   :: nStates
        this%ii = 7
    end function
    end subroutine
end module
However, simply saving the result of the multiplication off to a temporary variable and then passing that to the constructor resolves the issue:
        integer :: ii
    end type
    type :: SomeClass
    end type
    contains
        integer                   :: nStates
        this%ii = 7
    end function
        integer :: ii
        ii = integer1*integer2
        this%model = constructor(ii)
    end subroutine
end module
Regarding the warning ("the return value of this FUNCTION has not been defined") in my original post, it's not obvious to me that the code is invalid. A cursory look at the 2018 standard reveals nothing about this, but I have not looked through all of it. I will defer to those more knowledgeable on the topic.
Ron_Green
the bug ID is CMPLRLLVM-68777
