29650 Discussions
ICE with polymorphic defined assignment and -assume-realloc
John4
Valued Contributor I
Hi again,
For the code below, I get an ICE, caused the interface assignment(=) block.
module mod1
    type, public :: t1
        character(:), allocatable :: chars
    end type
        module procedure ASSIGN_t1, ASSIGN_t1_chars, ASSIGN_chars_t1
    end interface
contains
    subroutine bad_way(t, array)
        type(t1), allocatable, intent(OUT) :: t(:)
        character(*), intent(IN) :: array(:)
        integer :: i, j
        allocate (t(1:0))
        do i = 1, SIZE(array)
            t = [t, t1()]
            j = SIZE(t)
            t(j)%chars = array(i)
        enddo
    end subroutine
    elemental subroutine ASSIGN_t1(lhs, rhs)
        class(t1), intent(OUT) :: lhs
        class(t1), intent(IN)  :: rhs
    continue
        if (ALLOCATED(rhs%chars)) then
            lhs%chars = rhs%chars
        else
            lhs%chars = ''
        endif
    end subroutine
    elemental subroutine ASSIGN_t1_chars(lhs, char2)
        character(*), intent(IN)  :: char2
    continue
        lhs%chars = char2
    end subroutine
    elemental subroutine ASSIGN_chars_t1(char1, rhs)
        character(*), intent(OUT) :: char1
    continue
            char1 = rhs%chars
        else
            char1 = ''
        endif
    end subroutine
end module mod1
The ICE goes away by either using TYPE instead of CLASS in the ASSIGN_* subroutines, or using MOVE_ALLOC to reallocate t.
Kevin_D_Intel
Thank you for reporting this internal compiler error and the convenient reproducer. I reproduced it (even without -assume realloc_lhs) and reported it to our Developers (see internal tracking id below) for further analysis and repair. I will keep you updated on a fix as I learn it.
(Internal tracking id: DPD200361849)
