ICPROF and IFORT
alastor
I wanted to install IFORT on my computer (Intel Quadcoer), but I found in the downoload folder ICPROF files only. I am confused. These files include IFORT also?
I just installed it, but I don't know what to do now. What should I do, if I want to use the "ifort" command?
Thank you very much.
TimP
There are separate tar files including the icpc and ifort compilers, differing mainly by 1 letter (c or f) in the name. For 11.0, they install in the same tree.
alastor
Quoting - tim18
Thanks. But what should I do to make the command "ifort" usable.
When I type "ifort" I receive only error "command not found"
TimP
Quoting - alastor
When you have installed both icc and ifort 11.0, either the ifortvars or the iccvars scriipt is sufficient to set up the environment for both compilers.
