29381 Discussions
IFX 2025.3.0 Zero index is unintentionally used with "declare target"
jfuchs
I am experimenting with different OpenMP offloading snippets and stumbled upon the following issue. When using !$declare target on a buffer stored in a module and entering data with explicit memory management constructs, the buffer is then suddenly indexed from 0 instead of 1 when accessed in a target region. See the following reproducer down below. I compile this with IFX 2025.3.0 using:
ifx -O2 -fiopenmp -fopenmp-targets=spir64 main.F90
and run with:
OMP_TARGET_OFFLOAD=mandatory ./a.out
MODULE some_mod
    IMPLICIT NONE
    REAL, ALLOCATABLE, DIMENSION(:) :: buffer
    !$omp declare target(buffer)
CONTAINS
    SUBROUTINE init_data()
        INTEGER :: i
        ALLOCATE(buffer(3))
        DO i = 1, SIZE(buffer)
            buffer(i) = i
        END DO
        !$omp target enter data map(to: buffer)
    END SUBROUTINE init_data
    SUBROUTINE get_value(val, index)
        REAL, INTENT(OUT) :: val
        INTEGER, INTENT(IN) :: index
        val = buffer(index)
    END SUBROUTINE get_value
    SUBROUTINE finalize()
        !$omp target exit data map(release: buffer)
        DEALLOCATE(buffer)
    END SUBROUTINE finalize
END MODULE some_mod
PROGRAM main
    USE some_mod
    IMPLICIT NONE
    INTEGER :: i
    REAL :: val
    REAL :: values(3)
    CALL init_data()
    PRINT *, "Buffer host:"
    !PRINT*, "i = 1:", buffer(0) This should never be used here
    PRINT*, "i = 1:", buffer(1)
    PRINT*, "i = 2:", buffer(2)
    PRINT*, "i = 3:", buffer(3)
    PRINT *, "Buffer device:"
    !$omp target map(from: values)
        DO i = 1, 3
        CALL get_value(val, i)
        values(i) = val
        PRINT*, "i=",i,":",val
    END DO
    !$omp end target
    ! This will show: 2.000000 3.000000 0.0000000E+00
    ! Which is weird since the indices do not match after the target region
    PRINT *, "Values back on host:"
    PRINT *, values
    CALL finalize()
END PROGRAM main
Gives the output:
Buffer host:
i = 1: 1.000000
i = 2: 2.000000
i = 3: 3.000000
Buffer device:
i= 1 : 2.000000
i= 2 : 3.000000
i= 3 : 0.000000
One can also check that only in the target region PRINT*, buffer(0) gives 1.000000 which should be accessible with buffer(1)
I could not reproduce this behavior on other compilers (gfortran 13.3.0, nvfortran 25.9-0 or latest LLVM built from source).
Am I doing something unintended or unsupported for IFX or could this be a bug?
