29562 Discussions
IFX latest cannot pass complex components as arguments to subroutines
cdslab
The ifx latest Intel Fortran compiler release 2025.0 cannot compile the following line in a codebase that otherwise compiles with ifort and gfortran and seems to be fully compliant with the Fortran programming language standard.
Here is the error:error #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined. [UB]
call setUnifRand(rng, temp(1), lb%re, ub%re)
The last two arguments to the routine setUnifRand() are `intent(in)`. So, the error does not seem to make sense. Any help is appreciated.
Steve_Lionel
You'll need to provide a small source that demonstrates the problem. It is clear from the message that more context is needed.
cdslab
Hi Steve, Thank you for your response.
The library source code is over a million lines with a lot of dependencies.
Pasting the source code here is nearly impossible.
Instead, if you can please follow the instructions below to download and compile the source code:
  1.  download the source code from GitHub: https://github.com/cdslaborg/paramonte
    1. If you have access to git, try the following: git clone https://github.com/cdslaborg/paramonte.git
    2. Otherwise, download a zipped version of the source code from https://github.com/cdslaborg/paramonte/archive/refs/heads/main.zip
  2. Navigate to the root directory of the project where the LICENSE file exists.
  3. Ensure there is CMake (version > 3.18) is installed on the system + Intel OneAPI.
  4. On windows, try the following on the command line: install.bat --fc ifx
  5. On Linux or macOS, try the following on the command line: ./install.sh --fc ifx
    1. If the bash file is non-executable, make it so by typing: chmod +x ./install.sh
The above installation routes will take you to a number of files where compile time errors exist. The whole compilation process takes a few minutes, if it completes. To try ifort or gfortran, replace ifx in the above commands with the compiler name (if they are recognized on the command line). If you need more help with the installation, please see this page (https://www.cdslab.org/paramonte/generic/latest/installation/QUICKSTART.md) or let me know here. I am fairly confident many of the the compile errors are ifx bugs. Some of them generate an ICE.
For a full list of Intel compiler (ifort and ifx) bugs that we have encountered in this library, see this page: https://www.cdslab.org/paramonte/fortran/2/bug.html
If you need to customize the (default release) build (for example, with debug symbols), please consult the install scripts configuration flags: https://www.cdslab.org/paramonte/generic/latest/installation/install.config.md
or ask me here.
The source code is dense with preprocessing fences. If you like to see the final preprocessed source code, you can use the config flag `--fpp default`. See the relevant information here: https://www.cdslab.org/paramonte/generic/latest/installation/install.config.md#fpp
cdslab
Specifically, the error cited above (call setUnifRand(rng, temp(1), lb%re, ub%re)) happens in this source file line:
https://github.com/cdslaborg/paramonte/blob/56cc999ef8c995eaec4f3c89b52430b5ffc3dcce/src/fortran/main/pm_distUnif%40routines.inc.F90#L561
andrew_4619
It is useful to post bugs to allow improvement to the compiler and tools.  I read you five point instruction and to be honest to one who is not familiar with GIT and does not use Cmake that is as far as I would go. If the bug is as you describe making a sample program with  a handful of lines of code would take a few minutes. There are probably some key details that are unknown to us so for a third party to attempt this might involve chasing unicorns to find the combination of features/options necessary to reproduce the problem. A simple reproducer is the best way to engage  with the forum and get some resolution of the problem. My opinions.
JohnNichols
Honored Contributor I
I downloaded the f90 file with the source line.
I added the code to my ULARC program just as code and then ran IFX and IFORT.
I got the following errors, it will not compile as written in a stock standard 1968 Fortran program.
There are 31 errors.  At the moment I have other things to do, but you should understand that people do not have a lot of time, there are a couple of people here who would look at a reproducer, but you cannot expect hours of free work on something of limited interest.
Create a blank Fortran Program, add the Fortran module and then see if you can call the routine.   But get it compiling first.
John
Steve_Lionel
I took a few minutes to create a test case based on your subject line and one line of code:
program test
implicit none
complex :: c
c = (3.,4.)
call sub (c%re,c%im)
print *, c
contains
subroutine sub (re,im)
real, intent(in) :: re, im
print *, re, im
end subroutine sub
end program test
This matches your description. So, what do we get?
D:\Projects>ifx t.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.0 Build 20241008
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.41.34120.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:t.exe
-subsystem:console
t.obj
D:\Projects>t.exe
   3.000000       4.000000
 (3.000000,4.000000)
 As you can see, it works fine. Please put in the effort to create a small, reproducible test case. As I have recently observed in another thread, the act of doing so often results in discovering an error in your code.
andrew_4619
"....There are probably some key details that are unknown to us so for a third party to attempt this might involve chasing unicorns to find the combination of features/options necessary to reproduce the problem. " Dr Fortran  has now proved this, the Unicorn remains allusive.
TobiasK
@cdslab a start would be to show us the subroutine that you want to call.
JohnNichols
This is the code set pointed to by the questioner.   It is challenging.
!!!!    ParaMonte: Parallel Monte Carlo and Machine Learning Library.                                                           !!!!
!!!!    Copyright (C) 2012-present, The Computational Data Science Lab                                                          !!!!
!!!!    This file is part of the ParaMonte library.        !!!!
!!!!    LICENSE        !!!!
!!!!       https://github.com/cdslaborg/paramonte/blob/main/LICENSE.md                                                          !!!!
!>  \brief
!>  This include file contains the implementation of procedures in [pm_distUnif](@ref pm_distUnif).
!>  \author
!>  \FatemehBagheri, Wednesday 12:20 PM, September 22, 2021, Dallas, TX
        ! Define array elements.
#if     setUnifCDF_ENABLED && D0_ENABLED
#define GET_ELEMENT(ARRAY) ARRAY
#elif   setUnifCDF_ENABLED && D1_ENABLED
#define GET_ELEMENT(ARRAY) ARRAY(i)
#error  "Unrecognized interface."
#endif
        ! Define the optional RNG argument for the RNG procedures.
#if     getUnifRand_ENABLED || setUnifRand_ENABLED
#if     RNGD_ENABLED || RNGF_ENABLED
#define RNG
#elif   SM64_ENABLED || X256SSG_ENABLED || X256SSW_ENABLED
#define RNG rng,
#else
#endif
#endif
#if     getUnifCDF_ENABLED
#if     DD_ENABLED
        call setUnifCDF(cdf, x)
#elif   LU_ENABLED
        call setUnifCDF(cdf, x, lower, upper)
#else
#endif
        ! Set default bounds.
#if     IK_ENABLED && DD_ENABLED
        integer(IKG), parameter :: lower = 0_IKG, upper = 1_IKG
#elif   CK_ENABLED && DD_ENABLED
        complex(CKG), parameter :: lower = 0._CKG, upper = 1._CKG
#elif   RK_ENABLED && DD_ENABLED
        real(RKG), parameter :: lower = 0._RKG, upper = 1._RKG
#elif   !LU_ENABLED
#endif
        ! Define the normalization constant for vector computations.
#if     D1_ENABLED
        integer(IK) :: i
#if     IK_ENABLED && LU_ENABLED
        real(RKG) :: inverseUpperMinusLowerPlusOne
        inverseUpperMinusLowerPlusOne = 1._RKG / real(upper - lower + 1_IKG, RKG)
#elif   CK_ENABLED && LU_ENABLED
        complex(CKG) :: inverseUpperMinusLowerPlusOne
        inverseUpperMinusLowerPlusOne%re = 1._CKG / (upper%re - lower%re)
        inverseUpperMinusLowerPlusOne%im = 1._CKG / (upper%im - lower%im)
#elif   RK_ENABLED && LU_ENABLED
        inverseUpperMinusLowerPlusOne = 1._RKG / (upper - lower)
#elif   !DD_ENABLED
#endif
        CHECK_ASSERTION(__LINE__, size(cdf, kind = IK) == size(x, kind = IK), SK_"setUnifCDF(): The condition `size(cdf) == size(x)` must hold. size(cdf), size(x) = "//getStr([size(cdf, kind = IK), size(x, kind = IK)])) ! fpp
#elif   !D0_ENABLED
#endif
#if     LU_ENABLED && CK_ENABLED
        CHECK_ASSERTION(__LINE__, lower%re <= upper%re .and. lower%im <= upper%im, SK_"setUnifCDF(): The conditions `lower%re <= upper%re .and. lower%im <= upper%im` must hold. lower, upper = "//getStr([lower, upper])) ! fpp
#elif   LU_ENABLED
        CHECK_ASSERTION(__LINE__, lower <= upper, SK_"setUnifCDF(): The condition `lower <= upper` must hold. lower, upper = "//getStr([lower, upper])) ! fpp
#elif   !DD_ENABLED
#endif
        ! Begin the computation.
#if     D1_ENABLED
        do concurrent(i = 1 : size(x, kind = IK))
#endif
            ! integer.
#if         IK_ENABLED
            if (GET_ELEMENT(x) < lower) then
                GET_ELEMENT(cdf) = 0._RKG
            elseif (GET_ELEMENT(x) < upper) then
#if             DD_ENABLED
                GET_ELEMENT(cdf) = real(GET_ELEMENT(x) + 1_IKG, RKG) * 0.5_RKG
#elif           LU_ENABLED && D0_ENABLED
                GET_ELEMENT(cdf) = real(GET_ELEMENT(x) + 1_IKG - lower, RKG) / real(upper - lower + 1_IKG, RKG)
#elif           LU_ENABLED && D1_ENABLED
                GET_ELEMENT(cdf) = real(GET_ELEMENT(x) + 1_IKG - lower, RKG) * inverseUpperMinusLowerPlusOne
#else
#endif
            else
                GET_ELEMENT(cdf) = 1._RKG
            end if
            ! real.
#elif       RK_ENABLED
#if             DD_ENABLED
                GET_ELEMENT(cdf) = GET_ELEMENT(x)
                GET_ELEMENT(cdf) = (GET_ELEMENT(x) - lower) / (upper - lower)
                GET_ELEMENT(cdf) = (GET_ELEMENT(x) - lower) * inverseUpperMinusLowerPlusOne
#else
#endif
            else
            end if
            ! complex.
#elif       CK_ENABLED
            ! real part.
            if (GET_ELEMENT(x)%re < real(lower,CKG)) then
                GET_ELEMENT(cdf)%re = 0._CKG ! fpp
            elseif (GET_ELEMENT(x)%re < real(upper,CKG)) then
#if             DD_ENABLED
                GET_ELEMENT(cdf)%re = GET_ELEMENT(x)%re
                GET_ELEMENT(cdf)%re = (GET_ELEMENT(x)%re - real(lower,CKG)) / (real(upper,CKG) - real(lower,CKG))
                GET_ELEMENT(cdf)%re = (GET_ELEMENT(x)%re - real(lower,CKG)) * inverseUpperMinusLowerPlusOne%re
#else
#endif
            else
                GET_ELEMENT(cdf)%re = 1._CKG ! fpp
            end if
            ! imaginary part.
            if (GET_ELEMENT(x)%im < aimag(lower)) then
                GET_ELEMENT(cdf)%im = 0._CKG ! fpp
            elseif (GET_ELEMENT(x)%im < aimag(upper)) then
#if             DD_ENABLED
                GET_ELEMENT(cdf)%im = GET_ELEMENT(x)%im
                GET_ELEMENT(cdf)%im = (GET_ELEMENT(x)%im - aimag(lower)) / (aimag(upper) - aimag(lower))
                GET_ELEMENT(cdf)%im = (GET_ELEMENT(x)%im - aimag(lower)) * inverseUpperMinusLowerPlusOne%im
#else
#endif
            else
                GET_ELEMENT(cdf)%im = 1._CKG ! fpp
            end if
#else
#endif
#if     D1_ENABLED
        end do
#endif
#elif   splitmix64_typer_ENABLED
        integer(IK64) :: count
        if (present(seed)) then
            rng%state = seed
        else ! By default, the seed is randomly initialized for every new instance of the RNG.
            call system_clock(count)
            rng%state = 324108011427370141_IK64 ! This must be present, otherwise GNU 10.3 uninitliazation warning bug.
            rng%state = ieor(rng%state, count)
        end if
        if (present(imageID)) then
            CHECK_ASSERTION(__LINE__, 0_IK < imageID, \
            SK_"@splitmix64_typer(): The condition `0 < imageID` must hold. imageID = "//getStr(imageID))
            rng%state = ieor(rng%state, int(imageID, IK64))
        else
            rng%state = ieor(rng%state, 1_IK64)
        end if
#elif   setStateNext_ENABLED && SM64_ENABLED
        ! Equivalent to unsigned hexadecimal integers
        ! Z"9e3779b97f4a7c15", Z"bf58476d1ce4e5b9", Z"94d049bb133111eb"
        integer(IK64), parameter :: TRIPLE(3) = [ -7046029254386353131_IK64 &
                                                , -4658895280553007687_IK64 &
                                                , -7723592293110705685_IK64 ]
        if (rng%state < 0_IK64) then
            if (rng%state < -huge(0_IK64) - 1_IK64 - TRIPLE(1)) then
                rng%state = rng%state + huge(0_IK64) + 1_IK64
                rng%state = rng%state + TRIPLE(1)
            else
            end if
        else
        end if
        !rng%state = rng%state + TRIPLE(1)
        rng%stream = rng%state
        rng%stream = ieor(rng%stream, shiftr(rng%stream, 30)) * TRIPLE(2)
        rng%stream = ieor(rng%stream, shiftr(rng%stream, 27)) * TRIPLE(3)
        rng%stream = ieor(rng%stream, shiftr(rng%stream, 31))
#elif   xoshiro256ssg_typer_ENABLED || xoshiro256ssw_typer_ENABLED
        use pm_kind, only: IKG => IK64, RKG => RK64
        integer(IKG) :: ijump
        type(splitmix64_type) :: rngsm
        rngsm = splitmix64_type(seed = seed)
        call setUnifRand(rngsm, rng%state)
        call setStateJump(rng)
            CHECK_ASSERTION(__LINE__, 0_IK < imageID, SK_"@xoshiro256ssw_typer(): The condition `0 < imageID` must hold. imageID = "//getStr(imageID))
            do ijump = 2_IKG, imageID
            end do
        end if
#elif   setStateNext_ENABLED && (X256SSG_ENABLED || X256SSW_ENABLED)
        integer(IK64) :: dum
        rng%stream = ishftc(rng%state(2) * 5_IK64, 7) * 9_IK64
        dum = shiftl(rng%state(2), 17)
        rng%state(3) =   ieor(rng%state(3), rng%state(1))
        rng%state(4) =   ieor(rng%state(4), rng%state(2))
        rng%state(2) =   ieor(rng%state(2), rng%state(3))
        rng%state(1) =   ieor(rng%state(1), rng%state(4))
        rng%state(3) =   ieor(rng%state(3), dum)
        rng%state(4) = ishftc(rng%state(4), 45)
#if     X256SSG_ENABLED
        rng%pos = 0_IK
#endif
#elif   setStateJump_ENABLED && (X256SSG_ENABLED || X256SSW_ENABLED)
        integer(IK64)   :: state(4)
        integer(IK)     :: istate, ibit
#if     DJ_ENABLED
#define JUMP xoshiro256ssJump128
#elif   AJ_ENABLED
        CHECK_ASSERTION(__LINE__, size(jump, 1, IK) == size(rng%state, 1, IK), \
        SK_": The condition `size(jump, 1) == size(rng%state, 1)` must hold. size(jump), size(rng%state) = "\
        //getStr([size(jump, 1, IK), size(rng%state, 1, IK)]))
#else
#error  "Unreocgnized interface."
#endif
        state = 0_IK64
        ! Jump 2^128 (or 2^64) steps ahead from the specified `jump`.
        do istate = 1_IK, size(rng%state, 1, IK)
            do ibit = 0_IK, int(bit_size(rng%stream), IK) - 1_IK ! 63_IK
                if (btest(JUMP(istate), ibit)) state = ieor(state, rng%state) ! fpp
                call setStateNext(rng)
            end do
        end do
        rng%state = state
#undef  JUMP
#elif   getUnifRand_ENABLED && D0_ENABLED && LK_ENABLED && (RNGD_ENABLED || RNGF_ENABLED) && DD_ENABLED
        real :: dummy
        call random_number(dummy)
        rand = logical(dummy < .5, LKG)
#elif   getUnifRand_ENABLED && D0_ENABLED && LK_ENABLED && (SM64_ENABLED || X256SSW_ENABLED) && DD_ENABLED
        rand = logical(int(0, kind(rng%stream)) < rng%stream, LKG)
#elif   getUnifRand_ENABLED && D0_ENABLED && LK_ENABLED && X256SSG_ENABLED && DD_ENABLED
        rand = logical(btest(rng%stream, rng%pos), LKG)
        rng%pos = rng%pos + 1_IK
        if (rng%pos == xoshiro256ssStreamBitSize) call setStateNext(rng)
#elif   getUnifRand_ENABLED && (RNGD_ENABLED || RNGF_ENABLED || SM64_ENABLED || X256SSG_ENABLED || X256SSW_ENABLED) && LU_ENABLED
        call setUnifRand(RNG rand, lb, ub)
#elif   setUnifRand_ENABLED && D0_ENABLED && SK_ENABLED && DD_ENABLED
        integer(IK) :: i, randint
        do i = 1_IK, len(rand, IK)
            call setUnifRand(RNG randint, 1_IK, 127_IK)
            rand(i:i) = char(randint)
        end do
#elif   setUnifRand_ENABLED && D0_ENABLED && SK_ENABLED && LU_ENABLED
        integer(IK) :: lbLen, ubLen
        integer(IK) :: lbi, ubi
        lbLen = len(lb, IK)
        ubLen = len(ub, IK)
        CHECK_ASSERTION(__LINE__, lb <= ub, SK_"@setUnifRand(): The condition `lb <= ub` must hold. lb, ub = "//getStr([lb, ub]))
        CHECK_ASSERTION(__LINE__, lbLen == ubLen .or. lbLen == 1_IK .or. ubLen == 1_IK, SK_"@setUnifRand(): The condition `len(lb) == len(ub) .or. len(lb) == 1 .or. len(ub) == 1` must hold. len(lb), len(ub) = "//getStr([lbLen, ubLen]))
        CHECK_ASSERTION(__LINE__, lbLen == len(rand, IK) .or. lbLen == 1_IK, SK_"@setUnifRand(): The condition `len(lb) == len(rand) .or. len(lb) == 1`  must hold. len(lb), len(rand)  = "//getStr([lbLen, len(rand , IK)]))
        CHECK_ASSERTION(__LINE__, ubLen == len(rand, IK) .or. ubLen == 1_IK, SK_"@setUnifRand(): The condition `len(ub) == len(rand) .or. len(ub) == 1`  must hold. len(ub), len(rand)  = "//getStr([ubLen, len(rand , IK)]))
        if (1_IK < lbLen .and. 1_IK < ubLen) then
                call setUnifRand(RNG randint, ichar(lb(i:i), IK), ichar(ub(i:i), IK))
            end do
        elseif (1_IK == lbLen .and. 1_IK == ubLen) then
            lbi = ichar(lb, IK)
            ubi = ichar(ub, IK)
                call setUnifRand(RNG randint, lbi, ubi)
            end do
        elseif (1_IK == lbLen) then
            lbi = ichar(lb, IK)
                call setUnifRand(RNG randint, lbi, ichar(ub(i:i), IK))
            end do
        elseif (1_IK == ubLen) then
            ubi = ichar(ub, IK)
                call setUnifRand(RNG randint, ichar(lb(i:i), IK), ubi)
            end do
        elseif (len(rand, IK) /= 0_IK) then
            error stop "@setUnifRand(): Invalid user-specified input arguments. "& ! LCOV_EXCL_LINE
            //"Recompile & rerun with macro CHECK_ENABLED=1 for more information." ! LCOV_EXCL_LINE
        end if
#elif   setUnifRand_ENABLED && D0_ENABLED && IK_ENABLED && (RNGD_ENABLED || RNGF_ENABLED)
        ! Convert significant bit count to decimal precision.
        ! RKT: target real kind with at least `digits(rand)` bits.
        ! This is to ensure full coverage of the range of the specific-kind integer.
        integer, parameter :: RKT = selected_real_kind(floor(digits(rand) * log10(2._RKB)))
        integer, parameter :: RKG = merge(RKB, RKT, -6 < RKT .and. RKT < 0)
        real(RKG) :: temp
#if     DD_ENABLED
        !real(RKD) :: temp
        !call random_number(temp)
        ! \bug GNU Fortran compiler 10.3
        ! The following comment is a bug with `IKG = integer_kinds(5)`.
        !rand = floor(.5_RKD + temp, kind = IKG) ! rand = nint(temp, kind = IKG)
        integer(IKG), parameter :: lb = -huge(0_IKG), ub = +huge(0_IKG)
#elif   LU_ENABLED
#else
#endif
        if (lb + 1_IKG < ub) then
            ! early conversion to `real` avoids possible overflow with `huge` limits.
            ! rand = lb + int(temp * real(ub - lb + 1_IKG, kind(temp)), kind = IKG)
            rand = floor((1._RKG - temp) * real(lb, RKG) + temp * real(ub, RKG) + temp, kind = IKG)
        elseif (lb == ub) then
            rand = lb
        else
            if (temp < 0.5_RKG) then
                rand = lb
            else
                rand = ub
            end if
        end if
#elif   setUnifRand_ENABLED && D0_ENABLED && IK_ENABLED && (SM64_ENABLED || X256SSG_ENABLED || X256SSW_ENABLED)
        integer     , parameter :: IKS = kind(rng%stream)
        integer(IK) , parameter :: streamBitSize = bit_size(rng%stream) ! this has to remain generic, supportive of all RNGs.
#if     DD_ENABLED
        integer(IK) , parameter :: randBitSize = bit_size(rand)
        integer(IK) , parameter :: streamBitExcess = streamBitSize - randBitSize
        integer(IK) , parameter :: randStreamBitSizeRatio = int(real(randBitSize) / real(streamBitSize), IKG) + 1_IK
        integer(IKS)            :: buffer(randStreamBitSizeRatio)
        integer(IK)             :: ibuf
#if     X256SSG_ENABLED
        ibuf = rng%pos + randBitSize
        if (ibuf < streamBitSize) then
            rand = int(ibits(rng%stream, rng%pos, randBitSize), IKG)
            rng%pos = ibuf
            return
        elseif (ibuf == streamBitSize) then
            return
        end if
        ! Here, the `rand` kind is higher than kind(rng%stream).
        ! There is currently no neat solution in Fortran for greedy storage of the remaining bits.
        ! For now, accept the wasteful approach below for the greedy algorithm too.
        if (0 < rng%pos) call setStateNext(rng)
#else
        if (0_IK < streamBitExcess) then
            ! Both shifting and transfer below are possible solutions.
            ! The `abs` below, though redundant, bypasses the standard constraint.
            !rand = int(shiftr(rng%stream, abs(streamBitExcess)), IKG)
            rand = transfer(source = rng%stream, mold = rand)
            return
        elseif (0_IK == streamBitExcess) then
            rand = int(rng%stream, IKG)
            return
        end if
#endif
        do ibuf = 1_IK, randStreamBitSizeRatio
            buffer(ibuf) = rng%stream
        end do
        rand = transfer(source = buffer, mold = rand)
#elif   LU_ENABLED
        integer(IKG), parameter :: HUGE_IKG = huge(0_IKG)
        integer(IKG) :: scale, lbb, ubb, nzeros, nsignif, imask, temp, diff
        if (lb /= ub) then
            if (lb + 1_IKG == ub) then ! impossible range overflow.
#if             X256SSG_ENABLED
                if (btest(rng%stream, rng%pos)) then
                    rand = lb
                else
                    rand = ub
                end if
                if (rng%pos == streamBitSize) call setStateNext(rng)
#else
                if (0_IKS < rng%stream) then
                    rand = lb
                else
                    rand = ub
                end if
#endif
                return
            end if
            if (lb < 0_IKG .and. 0_IKG < ub) then ! possible range overflow.
                if (HUGE_IKG + lb < ub) then ! overflowed.
                    lbb = -lb - HUGE_IKG - 1_IKG
                    ubb = +ub - HUGE_IKG - 1_IKG
                    scale = ubb + lbb
                    nzeros = 0_IKG
                else
                    scale = ub - lb
                    nzeros = int(leadz(scale), IKG)
                end if
                !scale = ub .uadd. -lb
            else ! impossible range overflow (assuming `lb < ub`).
                scale = ub - lb
            end if
            nsignif = bit_size(scale) - nzeros
            imask = shiftr(not(0_IKG), nzeros)
            loopTry: do
                call setUnifRand(rng, temp)
                rand = iand(temp, imask)
                if(rand <= scale) exit loopTry
                diff = nzeros
                loopReject: do
                    if(diff < nsignif) exit loopReject
                    temp = shiftr(temp, nsignif)
                    diff = diff - nsignif
                end do loopReject
            end do loopTry
            rand = rand + lb
        else
            rand = lb
        end if
#else
#endif
#elif   setUnifRand_ENABLED && D0_ENABLED && LK_ENABLED && (RNGD_ENABLED || RNGF_ENABLED)
#if     DD_ENABLED
        real :: dummy
        rand = logical(dummy < .5, kind = LKG)
#elif   LU_ENABLED
        real :: dummy
        if (lb .neqv. ub) then
        else
            rand = lb
        end if
#else
#endif
#elif   setUnifRand_ENABLED && D0_ENABLED && LK_ENABLED && (SM64_ENABLED || X256SSG_ENABLED || X256SSW_ENABLED)
#if     DD_ENABLED && X256SSG_ENABLED
#elif   DD_ENABLED && (SM64_ENABLED || X256SSW_ENABLED)
        rand = logical(int(0, kind(rng%stream)) < rng%stream, kind = LKG)
#elif   LU_ENABLED
            call setUnifRand(rng, rand)
        else
            rand = lb
        end if
#else
#endif
#elif   setUnifRand_ENABLED && D0_ENABLED && CK_ENABLED
        ! Curse you Intel bug.
#if     __INTEL_COMPILER
        real(CKG) :: temp(2)
#if     DD_ENABLED
        call setUnifRand(RNG temp)
#elif   LU_ENABLED
        if (lb /= ub) then
            call setUnifRand(RNG temp(1), lb%re, ub%re)
            call setUnifRand(RNG temp(2), lb%im, ub%im)
            !call setUnifRand(RNG temp(1), real(lb, CKG), real(ub, CKG))
            !call setUnifRand(RNG temp(2), aimag(lb), aimag(ub))
        else
            rand = lb
        end if
#else
#endif
        rand = cmplx(temp(1), temp(2), CKG)
#else
#if     DD_ENABLED
        call setUnifRand(RNG rand%re)
        call setUnifRand(RNG rand%im)
#elif   LU_ENABLED
        if (lb /= ub) then
            call setUnifRand(RNG rand%re, lb%re, ub%re)
            call setUnifRand(RNG rand%im, lb%im, ub%im)
            !call setUnifRand(RNG rand%re, real(lb, CKG), real(ub, CKG))
            !call setUnifRand(RNG rand%im, aimag(lb), aimag(ub))
        else
            rand = lb
        end if
#else
#endif
#endif
#elif   setUnifRand_ENABLED && D0_ENABLED && RK_ENABLED && (RNGD_ENABLED || RNGF_ENABLED)
#if     DD_ENABLED
        call random_number(rand)
#elif   LU_ENABLED
        if (lb /= ub) then
            CHECK_ASSERTION(__LINE__, lb < ub, SK_"@setUnifRand(): The condition `lb <= ub` must hold. lb, ub = "//getStr([lb, ub]))
            ! The following loop ensures the random number falls in the half-open range `[lb, ub)`,
            ! even in the extreme case when `ub = lb + spacing(lb)`.
            do
                !rand = lb + rand * (ub - lb)
                ! The product expansion, although more expensive, avoids possible overflow with `huge` limits.
                rand = (1._RKG - rand) * lb + rand * ub
                ! The equality (instead of <) ensures NAN cases are handled gracefully without infinite loop.
                ! Hard lesson learned.
                !if (rand < ub) return
                if (ub <= rand) cycle
                exit
            end do
        else
            rand = lb
        end if
#else
#endif
#elif   setUnifRand_ENABLED && D0_ENABLED && RK_ENABLED && (SM64_ENABLED || X256SSG_ENABLED || X256SSW_ENABLED)
#if     DD_ENABLED
        integer     , parameter :: DIGITS_RKG = digits(rand)
        integer     , parameter :: DIGITS_RNG = digits(rng%stream)
!#if     X256SSG_ENABLED
        ! The following original approach is too costly.
        ! We will instead use the wasteful approach for the greedy.
        !real(RKG)   , parameter :: INVPDIG_RKG = 1._RKG / 2._RKG**DIGITS_RKG
        !integer                 :: remaining, remainders
        !remainders = DIGITS_RNG - DIGITS_RKG - rng%pos
        !if (0 < remainders) then
        !    rand = real(ibits(rng%stream, rng%pos, DIGITS_RKG), RKG) * INVPDIG_RKG
        !    rng%pos = rng%pos + DIGITS_RKG
        !else
        !    remainders = DIGITS_RNG - rng%pos
        !    rand = real(ibits(rng%stream, rng%pos, remainders), RKG) * 0.5_RKG**remainders
        !    call setStateNext(rng)
        !    remaining = DIGITS_RKG - remainders
        !    do
        !        remainders = remaining - DIGITS_RNG
        !        if (0 < remainders) then ! use full stream and cycle
        !            rand = (rand + real(abs(rng%stream), RKG)) * 0.5_RKG**DIGITS_RNG
        !            remaining = remainders
        !        else ! use part of stream and exit.
        !            rng%pos = -remainders
        !            rand = (rand + real(ibits(rng%stream, 0_IK, rng%pos), RKG)) * 0.5_RKG**rng%pos
        !            return
        !        end if
        !    end do
        !end if
!#else
        integer                 :: i
        integer     , parameter :: NUMBIT_RNG = bit_size(rng%stream) ! DIGITS_RNG + 1 ! The `1` makes up for the missing sign bit in the counting.
        integer     , parameter :: REPEAT_RNG = int(real(DIGITS_RKG) / real(DIGITS_RNG))
        integer     , parameter :: REMAINDERS = DIGITS_RKG - DIGITS_RNG * REPEAT_RNG
        ! bit-shifting or integer exponentiation overflows for exponent 63. Use real exponentation.
        real(RKG)   , parameter :: INV_POWREM = 1._RKG / 2._RKG**REMAINDERS ! real(shiftl(1_IKS, REMAINDERS), RKG) ! 1. / 2_IKS**REMAINDERS
        real(RKG)   , parameter :: INV_POWDIG = 1._RKG / 2._RKG**DIGITS_RNG ! real(shiftl(1_IKS, DIGITS_RNG), RKG) ! 1. / 2_IKS**DIGITS_RNG
#if     X256SSG_ENABLED
        if (DIGITS_RNG < REMAINDERS + rng%pos) call setStateNext(rng)
        rand = real(shiftr(rng%stream, NUMBIT_RNG - REMAINDERS + rng%pos), RKG) * INV_POWREM
#else
        rand = real(shiftr(rng%stream, NUMBIT_RNG - REMAINDERS), RKG) * INV_POWREM
#endif
        do i = 1, REPEAT_RNG ! exists only for higher-than-double precision real kinds.
            rand = (rand + real(shiftr(rng%stream, NUMBIT_RNG - DIGITS_RNG), RKG)) * INV_POWDIG
        end do
!#endif
#elif   LU_ENABLED
        if (lb /= ub) then
            do
                exit
            end do
        else
            rand = lb
        end if
#else
#endif
#elif   setUnifRand_ENABLED && !D0_ENABLED && (RNGD_ENABLED || RNGF_ENABLED || SM64_ENABLED || X256SSG_ENABLED || X256SSW_ENABLED)
        ! Define the bounds.
#if     DD_ENABLED
#define BOUNDS
#elif   LU_ENABLED
#define BOUNDS, lb, ub
#else
#endif
#if     D1_ENABLED
        integer(IK) :: irow, nrow
        nrow = size(rand, 1, IK)
        do irow = 1, nrow
            call setUnifRand(RNG rand(irow) BOUNDS)
        end do
#elif   D2_ENABLED
        integer(IK) :: irow, nrow, icol, ncol
        ncol = size(rand, 2, IK)
        do icol = 1, size(rand, 2, IK)
            do irow = 1, nrow
                call setUnifRand(RNG rand(irow, icol) BOUNDS)
            end do
        end do
#elif   D3_ENABLED
        integer(IK) :: irow, nrow, icol, ncol, idim, ndim
        ndim = size(rand, 3, IK)
        do idim = 1, ndim
            do icol = 1, ncol
                do irow = 1, nrow
                    call setUnifRand(RNG rand(irow, icol, idim) BOUNDS)
                end do
            end do
        end do
#else
#endif
#undef  BOUNDS
#else
#endif
#undef  GET_ELEMENT
#undef  RNG
 Calling up line 561.
JohnNichols
Dear Human from the CDS Lab:
1. The person who wrote the code is on your web site, perhaps you should ask that person as they are likely to be more familiar with the code
2. And if they are using it then one would expect that person to keep up to date with compilers
It also helpful to have a name and not a lab as the user name.
John
Steve_Lionel
We need to see the source of routine setUnifRand. Seeing the call isn't helpful.
