IFX optimization bug suspected
mecej4
The program listed below involves only integers, and is deterministic. When compiled with the IFX 20211123 build with /Od on Windows 11, the output is
863862222379
Ifort and other Fortran compilers give the same result. When  IFX is used with /O2, etc., the output is
863862222378
The program does cause integer overflow, but the code is part of a random number generator, performing lots of shifts and bit operations, so the overflow should be handled as usual.
Here is the program source.
Module sk64_m
   Implicit None
   Integer, Parameter :: i8 = selected_int_kind(18)
   Integer (Kind=i8) :: q = 5797281239641574547_i8, carry = 36243678541_i8
Contains
   subroutine refill()
      Implicit None
      Integer (Kind=i8) :: z
      z = ishft(ishft(q,41),-1) + ishft(ishft(q,39),-1) + ishft(carry,-1)
      carry = ishft(q, -23) + ishft(q, -25) + ishft(z, -63)
      print '(i21)',carry
      Return
   End subroutine refill
End Module sk64_m
Program tk64
   Use sk64_m
   call refill()
End Program tk64
Steve_Lionel
You can't rely on results that overflow - the compiler is allowed to make assumptions that won't happen.
cryptogram
Since everything is known ahead of time,  it would be interesting to see how much code was removed by the optimization.
In theory, it could have precomputed the final value of carry, and just printed out the precomputed value.  The difference would
then be in how the compiler itself handled the computation rather than how it would have worked if all the computations were performed in compiled code.
jimdempseyatthecove
Does (your version) of ifx generate the correct result with optimizations disabled?
The ishft should be treating the numbers as unsigned (even though Fortran only supports signed INTEGERs).
Look at the disassembly code to verify that the shift instructions are unsigned.
Secondly, you have a value (q) that is shifted left nn positions immediately followed by shift right 1 position. Check to see if the optimization contains both shifts as opposed to shifting left nn-1 positions. This are not the same as the correct way will always result in 0 in the msb position and the incorrect way will not.
Jim Dempsey
