IFX problem
jserf
I am having problems with OMP ATOMIC clauses - IFX cannot compile them into a fortran code.
The code does compile with ifort.
The code is large, but the clause is simple (k is distributed;  it will race without atomic):
!$OMP ATOMIC UPDATE
       var(k)=var(k)+factor
The error I get is below (first few lines)
LLVM ERROR: Cannot select: 0x6b5d4b0: f32,ch = AtomicLoadAdd<(load store monotonic (s32) on %ir.<badref>)> 0x72ed5d0:1, 0x7444a60, 0x72edb80
0x7444a60: i64 = add 0x72ed5d0, 0x7111720
0x72ed5d0: i64,ch = load<(dereferenceable load (s64) from ``, align 16, !tbaa )> 0x6b5caa0:1, 0x6b5d360, undef:i64
0x6b5d360: i64 = add nuw 0x71115d0, Constant:i64<496>
0x71115d0: i64,ch = load<(load (s64) from got, align 32)> 0x59b1ab0, 0x75da9b0, undef:i64
0x75da9b0: i64 = X86ISD::WrapperRIP TargetGlobalAddress:i64<> 0 [TF=5]
0x7444050: i64 = TargetGlobalAddress<> 0 [TF=5]
0x6fabea0: i64 = undef
0x71113a0: i64 = Constant<496>
I do have some ATOMICS that can compile OK, they address scalars and 2-d arrays, not vectors.
Would be grateful for any suggestions.
Thank you.
Steve_Lionel
You will need to attach a (small if possible) test case so that the Intel developers can investigate. Before you do that, try the latest version that was published just the other day.
jserf2
      program test
      POINTER (PTRA,ARR(1000))
c
!$OMP PARALLEL DO SCHEDULE(STATIC,20)
      do 10 i=1,1000
!$OMP ATOMIC
       ARR(I)=ARR(I)+SQRT(float(I))
 10   CONTINUE
!$OMP END PARALLEL DO
C
      stop
      end
ifx -c -Qopenmp  TEST.f
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.2.0 Build 20250605
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
LLVM ERROR: Cannot select: 0x1c62e475708: f32,ch = AtomicLoadAdd<(load store monotonic (s32) on ``)> 0x1c62e17fe18, undef:i64, 0x1c62e475a50
0x1c62e474b98: i64 = undef
etc
