IMSL Assurance Test failed
skravoof
Dear all,
I have install intel fortran compiler with imsl64 bit on win7 64 bit version. Mpich2 also installed. When I run the IMSL Assurance Test through commond prompt usingrun_eiat.bat most of them come as Access is deined. And I can't figure out whats wrong?
Thanks in advance
skravoof
Can you show the log of the commands and results? I don't know what you mean by "most of them come as Access is denied". Can you build and run the "validate" program?
skravoof
I had the similar problem when I used build_eiat at the command prompt. error is something like: 'ifort' not recognized as internal or external command. Any suggestions?
Ravoof
mecej4
When you installed Intel Fortran and IMSL, did you allow the installers to modify the environment? If not, which is what I suspect from the error message 'ifort not recognized', you need to use the command window under Start-Programs-Intel...-Command.., rather than an ordinary command window from Windows-Accessories. The former is run from a batch file that sets the correct environmental variables to allow the Intel Fortran compiler to be run.
As a first step, forget about IMSL and make the changes needed to allow the compilation and running of a Hello World Fortran program. Then add the IMSL capability.
