29434 Discussions
IMSL Library not included in INTEL PARALLEL STUDIO XE COMPOSER for WINDOWS 2018
prabha_d_
Hi ,
IMSL library is not included in Intel studio XE 2018 for windows . I have used IMSL functions in my earlier code. How Can I build that program in the  parallel studio 2018 without IMSL library.
Thanks in advance
prabha_d_
Hi , I already bought Intel parallel studio XE composer edition 2018 for windows , which does not include IMSL library, I am unable to bulid my project in this . Can I buy IMSL separately and integrate it with Parallel studio XE 2018 .
DavidWhite
Valued Contributor II
If you search for IMSL on the intel website, you will find the page that enables you to purchase IMSL as an Add-In to your current compiler.
andrew_4619
MKL is provided which may do what you need.
prabha_d_
Thanks for your reply. Can I solve ODE (ordinary Differential Equations ) and function minimization  in MKL library
Thanks again for your support
mecej4
There is no ODE solver in MKL, but a number of excellent solvers are available elsewhere. Intel itself has an unsupported but very capable ODE-IVP library at https://software.intel.com/en-us/articles/intel-ordinary-differential-equations-solver-library . It would help if you could describe whether your ODE problem is an IVP, BVP or EVP, and whether your ODE is stiff.
Likewise, before selecting a solver to replace UMPOL (which, being based on a polytope algorithm, is quite slow for analytically defined functions, especially if the function gradient can be calculated analytically) consult the decision tree at http://plato.la.asu.edu/guide.html .
Greg_T_
Another open source for mathematical routines is the NIST Guide To Available Mathematical Software (GAMS): https://gams.nist.gov/
Use the "problem keyword" search for "ordinary differential equations" to get a list of routines for various types of solvers.
I've used routines from GAMS successfully.
Regards, Greg T.
prabha_d_
Thanks to all for your reply !! Please suggest me how can I buy IMSL library separately which will work with intel parallel studio XE composer 2018
regards
prabha
mecej4
IMSL 7.0 from Intel, as part of a package or as an add-on:
     https://software.intel.com/en-us/rogue-wave-imsl-fortran-library/try-buy
IMSL Fortran 7.1 from Rogue Wave
     https://www.roguewave.com/products-services/request-quote
prabha_d_
I bought IMSL 7.0 library from intel and installed it with intel parallel studio 2018 . still I am finding difficulty to run my Fortran code. please help me to solve the program. I have attached error copy here.
mecej4
IMSL is an optional package (no longer available from Intel), so you have to configure Visual Studio (i.e., the compiler, linker and the runtime environment) to use it. Please see https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries/ .
Steve_Lionel
I'll note that the Intel article was written assuming the IMSL package as supplied by Intel. While it should generally be applicable to separately purchased IMSL, it's possible that some minor aspects may need tweaking.
mecej4
According to what was stated in #10, IMSL was purchased from Intel, so the directions should smooth her way:
