29487 Discussions
IMSL Library of Compaq Visual Fortran
mbaureis
Hello.
Is it possible to use the IMSL library, which was included in CVF 6.5 prof., in combination with Intel Visual Fortran Composer XE for Windows?
Thanks and kind regards
Martin
TimP
Did you read the posts about waiting for a new version of IMSL? If the IMSL for ifort 11 doesn't work with current ifort, why would you ask for a much older one to work?
If it did work, you would be stuck with using the 32-bit CVF compatibility options of ifort.
The answer to the original question is "no, it won't work". You'll get linking and run-time errors.
