IMSL : RONE and RSTEP routines
MAURICE_J_
HI,
I have been hired (I am a freelance) to translate R scripts to FORTRAN.
I found an old fortran library using RONE and RSTEP routines from an old IMSL DLL. My client (customer) is rich but buying IMSL will take more than 3 months and he told me that it doesn't worth the cost : the R script is only used by 5 or 6 persons.
My question is : has someone writen 'open source' routines doing the same work than RON and RSTEP ?
Jean in France
andrew_4619
Use MKL  which comes with intel fortran i think RONE would be GELSD but you would needs to study the help manual.
mecej4
The routines RONE is quite comprehensive, and returns lots of statistical information. It may be the case that you only use a small subset of those statistics. If so, specify only those and you may be able to find an open source or MKL equivalent.
