IMSL and MKL linking
HKort
I am new to using the IMSL libraries. I found that I need to include the file link_fnl_static_hpc.h. The hpc indicates that Intel MKL libraries are linked as well. Is there a way to compile the code without MKL so that I can use the file link_fnl_static.h? My own code does not require MKL.
Haje
Use 'link_fnl_static.h'. You will also need to add:
!DEC$ OBJCOMMENT LIB:'libguide.lib'
after that.
HKort
Thank you Steve, I will try that out.
Haje
