29486 Discussions
IMSL and MKL selection from compiler directives
elquin
I'm using Intel Visual Fortran v.11.1.065 under Windows 7 64 bit.
What I want to make is related with compiler directives, especially for math library.
Here's my idea :
1. There exist two kinds of debug configuration, for IMSL and MKL.
Thus command line arguments contains library-specific environment variables.
2. In code, compiler directive determine which math library is selected.
Then, library-specific functions can also be selected in code.
However, I don't know how to set the compiler directives for determining libraries.
HK
For IMSL, a set of INCLUDE files is provided that have the appropriate !DIR$ OBJCOMMENT directives - you need several. While nothing similar exists for MKL you can certainly add your own OBJCOMMENT directives for the set of MKL libraries you need.
elquin
Thank you, Mr. Lionel.
However, what I really want to know is how to make the code know which math library will be used in debugging.
After that, the compiler directives like !DIR$ OBJCOMMENT will be used in the code.
HK
elquin
HK
I guess I didn't fully understand your question. There are not debug versions of IMSL and MKL. What do you want to be different in a debug configuration?
