IMSL quadrature and modules
rschaa
Hi there,
I like to integrate a function from within a module. The module consists of a subroutine and a function.
See also IMSL documentation page 604 (QDAG).
The example from the IMSL doc runs just fine, but when I integrate this example in a module it fails with a unhandled exception;
The subroutine in my module is the main program from the IMSL example and there is the function.
The error should be due to false initializiations I guess...
Some code of mine:
MODULE ABEL
CONTAINS
SUBROUTINE S_ABEL
USE IMSL
REAL :: F
EXTERNAL :: QDAG
CALL QDAG(F,...)
END SUBROUTINE S_ABEL
REAl FUNCTION F(X)
REAL :: X,EXP
INTRINSIC :: EXP
F= X*EXP(X)
RETURN
END FUNCTION F
END MODULE ABEL
I tried also EXTERNAL :: QDAG, F like in the IMSL example, but this fails also ...
Anybody has a hint?
Thanks!
-Ralf
Complete error message is:
Loaded 'C:WINNTsystem32 tdll.dll', no matching symbolic information found.
Loaded 'C:WINNTsystem32KERNEL32.DLL', no matching symbolic information found.
Loaded 'C:WINNTsystem32IMAGEHLP.DLL', no matching symbolic information found.
First-chance exception in abelV0.exe: 0xC0000005: Access Violation.
Loaded 'C:WINNTsystem32msvcrt.dll', no matching symbolic information found.
Loaded 'C:WINNTsystem32dbghelp.dll', no matching symbolic information found.
rschaa
okay, I found a solution on another website:
http://dbforums.com/t890214.html
actually the function should be moved outside of the module and it then should be declared as an external.
Cheers
-Ralf
