INQUIRE does not recognize file mode bits
rudi-gaelzer
Using:
OS: Linux 4.16.13-300.fc28.x86_64 #1 SMP Wed May 30 14:31:00 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux (Fedora 28)
Shell: GNU bash, version 4.4.19(1)-release (x86_64-redhat-linux-gnu)
Compiler: Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.2.199 Build 20180210
The INQUIRE statement is not recognizing the file mode bits for this combination of OS/shell/compiler.
Consider the simple test which get info about two data files: temp.dat and temp_ro.dat; the first with rw attributes and the second read-only:
-rw-r--r--. 1 rudi plasmas     18 abr 11 17:33 temp.dat
-r--r--r--. 1 rudi plasmas     18 jun  5 11:55 temp_ro.dat
Accessed with the following code:
program tes_inquire_2
implicit none
logical :: fexist, fopen
character(len= *), parameter :: file_exist=  'temp.dat'        ! Existing file
character(len= *), parameter :: file_ro=     'temp_ro.dat'     ! Existing file, with read-only attribute
character(len= 30) :: fcread, fcwrite, fcrw
integer :: ios
! Existing file, with rw attributes
inquire(file= file_exist, exist= fexist, opened= fopen, iostat= ios, &
        read= fcread, write= fcwrite, readwrite= fcrw)
print'(a,/,2a)', '----------------------------------', 'About file '//file_exist//':'
write(*, '(a,g0)')'File exist(?): ', fexist
write(*, '(a,g0)')'File is opened(?): ', fopen
write(*, '(2a)')'File can be opened for read only(?):  ', trim(fcread)
write(*, '(2a)')'File can be opened for write only(?): ', trim(fcwrite)
write(*, '(2a)')'File can be opened for read/write(?): ', trim(fcrw)
write(*, '(a,g0)')'iostatus= ', ios
inquire(file= file_ro, exist= fexist, opened= fopen, iostat= ios, &
print'(/,a,/,2a)', '----------------------------------', 'About file '//file_ro//':'
end program tes_inquire_2
Compiling and running with ifort:
>ifort tes_inquire_2.f90
>./a.out
About file temp.dat:
File exist(?): T
File is opened(?): F
File can be opened for read only(?):  UNKNOWN
File can be opened for write only(?): UNKNOWN
File can be opened for read/write(?): UNKNOWN
iostatus= 0
About file temp_ro.dat:
File exist(?): T
iostatus= 0
OTOH, gfortran will reply the correct attributes:
>gfortran tes_inquire_2.f90
>./a.out
File exist(?): T
File can be opened for read only(?):  YES
File can be opened for write only(?): YES
File can be opened for read/write(?): YES
iostatus= 0
File exist(?): T
File can be opened for write only(?): NO
iostatus= 0
I could not find any relevant compiler option for ifort, after a quick look at the manual...
Is this the expected behavior?
Juergen_R_R
Valued Contributor II
It is not an unexpected behavior. Note e.g. the description the Fortran 2003 Handbook by Adams et al., p. 347: "In an inquire by unit to a disconnected unit or by file to a file that is not connected, the OPENED specifier will return false and many other specifiers are not useful and return UNKNOWN or UNDEFINED." This is what you experience with the Intel compiler. nagfor gives out YES YES YES, YES NO NO, so disagrees with gfortran actually. If you e.g. include an open statement like open (unit = 7, file = file_exist) the Intel compiler now also accesses the wanted information. I think there is no flag to change this behavior. If the file is not conneceted it is up to the processor (i.e. compiler) on what to return and UNKNOWN is the safest bet.
Harald1
New Contributor II
Jürgen,
sorry, but I have to say this is a rather poor excuse for the Intel compiler (and a few others) to not provide a cheap solution when checking that status of many files.  The result could be obtained by a simple stat(2) that needs only the metadata server of a distributed filesystem (e.g. Lustre).  However, the overhead of actually opening and closing a file likely produces unnecessary system load.
Of course you're right that the standard always allowed to return UNKNOWN.  But NAG, NEC, and GNU handle this just fine, so I consider this a quality-of-implementation issue.
Cheers,
Harald
rudi-gaelzer
I did some other testing, but not exactly what you suggested.  Indeed, appending the following bit to the source:
print'(a,/,a)', '----------------------------------', 'opening files and inquiring again:'
open(file= file_exist, newunit= nio1, action= 'read', iostat= ios)
open(file= file_ro, newunit= nio1, action= 'read', iostat= ios)
print'(2a)', 'About file '//file_exist//':'
print'(2a)', 'About file '//file_ro//':'
Now gives the expected reply:
>./a.out
File exist(?): T
iostatus= 0
File exist(?): T
iostatus= 0
File exist(?): T
File is opened(?): T
File can be opened for read/write(?): NO
File exist(?): T
I then had the idea to try to open a read-only file for write access:
program tes_inquire_3
implicit none
character(len= 200) :: iomess
integer :: ios, nio
print'(/,a,/,2a)', '----------------------------------', 'Opening '//file_ro//' for write-only access:'
open(file= file_ro, newunit= nio, action= 'write', iostat= ios, iomsg= iomess)
write(*, '(2a)')'Error message: '//trim(iomess)
print'(/,a,/,2a)', '----------------------------------', 'Opening '//file_ro//' for read/write access:'
open(file= file_ro, newunit= nio, action= 'readwrite', iostat= ios, iomsg= iomess)
end program tes_inquire_3
Fortunately, the program does not allow this action:
>ifort tes_inquire_3.f90
>./a.out
File exist(?): T
iostatus= 0
Opening temp_ro.dat for write-only access:
iostatus= 9
Error message: permission to access file denied, unit -129, file /home/rudi/comp/for/f2008/temp/Input_Output/temp_ro.dat
Opening temp_ro.dat for read/write access:
iostatus= 0
This is what I wanted from the beginning and it works for me.
Now, about your other comment:
I have a copy of Adam's book and indeed it says that, but is pretty vague...
I read the standard (J3/10-007r1 F2008 Working Document), section 9.10, and could not find any caveat for inquire by file for the read, write and readwrite specifiers other than the option to return 'UNKNOWN'.  So, I implicitly assumed that ifort would correctly identify the attributes of an unopened file...
Anyway, thanks for the tips.
