INTEGER input question
NotThatItMatters
A development in my code has left me with the following "simple" INTEGER input question.  A single line in a text file has either one or two integer values, but a priori I do not know which.  How might I read this line and determine how many inputs?
My attempt was the following:
I2 = -1
READ(IOUNIT, *, ERR = 11) I1, I2
11 CONTINUE
IF (I2 == -1) THEN
! Do something appropriate to initialize I2
END IF
This fails because the error may have been triggered, but the READ statement is now gobbling more input.  What is the "best" way to do this?
jimdempseyatthecove
And for your follow-up question:
program read_x_y
    implicit none
    integer, parameter :: MaxInputLine=128
    character(len=MaxInputLine) :: InputLine
    integer, parameter :: N = 10
    integer :: Array(N)
    integer :: comma, i
    read(*,'(A)') InputLine
    Array = -1
    do i=1,N
        if(InputLine == ' ') exit
        read(InputLine,*) Array(i)
        comma = index(InputLine,',')
        if(comma <= 0) exit
        InputLine = InputLine(comma+1:)
    end do
    print *, Array
end program read_x_y
Jim Dempsey
NotThatItMatters
Note: I am using Fortran 2003 as the standard for my code, so non-advancing input with appropriate settings is a viable option.
jimdempseyatthecove
program read_x_y
    implicit none
    integer :: i1, i2,comma
    read(InputLine,*) i1
    i2=-1
    if(comma > 0) read(InputLine(comma+1:),*) i2
    print *, i1,i2
The above is one way to do this. You may want to improve the delimiter detection (space, tab, accept and evaluate an expression, etc...)
Jim Dempsey
jimdempseyatthecove
program read_x_y
    implicit none
    integer :: Array(N)
    integer :: comma, i
    Array = -1
    do i=1,N
        if(comma <= 0) exit
    end do
    print *, Array
Jim Dempsey
NotThatItMatters
Thank you.  I had done some Googling and found a similar solution on StackOverflow.  It is working, and yours is more generic.  I will be implementing as such.
jimdempseyatthecove
You might want to look on this forum a little more. Someone posted a really good input parser.
https://software.intel.com/pt-br/comment/1478224
There are more.
Jim Dempsey
