29657 Discussions
INTENT(IN) polymorphic argument with pointer components - reject valid code
MR
(This was also discussed on comp.lang.fortran: https://groups.google.com/forum/#!topic/comp.lang.fortran/dPaOv53SGeA)
ifort does not compile s1 in the attached code (while accepting s2 and s3 which do essentially the same thing):
$ ifort -c test.f90 -o test.o
test.f90(17): error #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined.   [VAR]
   var%i = 3
compilation aborted for test.f90 (code 1)
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.2.181 Build 20160204
This seems a bug in ifort, since the assignment defines the target of the pointer, not the pointer itself.
Here is the code
module m
 implicit none
 type, abstract :: t_a
 end type t_a
 type, extends(t_a), abstract :: t_b
  integer, pointer :: i => null()
 end type t_b
contains
 subroutine s1(var)
  class(t_a), intent(in) :: var
   select type(var); class is(t_b)
   var%i = 3
   end select
 end subroutine s1
 subroutine s2(var)
  class(t_b), intent(in) :: var
   var%i = 3
 end subroutine s2
 subroutine s3(var)
  integer, pointer :: tmp
   tmp => var%i
   tmp = 3
   end select
 end subroutine s3
end module m
Thanks - we'll take a look.
Escalated as issue DPD200411900, Odd that we didn't see this before. The error doesn't occur if the dummy isn't polymorphic. Thanks.
MR
OK, thank you!
Marco
jimdempseyatthecove
Am I missing something here?
In s1 and s2, why is var%i=3 permitted when var is declared as intent(in)?
In s3, similar issue where  var is declared as intent(in) and the pointer tmp is defined to point to var. Doesn't the pointer "inherit" the intent(in) of that which it points to?
Jim Dempsey
The question of what INTENT means for pointers has come up in standard discussions over the years. The result was that the standard says INTENT applies only to the definition status of the pointer itself - NOT the target it points to. In the program here, it is the target being modified and that is not protected by INTENT(IN).
jimdempseyatthecove
I see - an ambiguity between the actual object and the abstraction of the object.
In Fortran, the expressions containing either, it is indistinguishable.
 end type t_a
#if defined(USE_POINTER)
#else
  integer :: i
#endif
 end type t_b
contains
 subroutine s1(var)
   var%i = 3 ! syntax indistinguishable between I being pointer or scalar integer
   end select
 end subroutine s1
Well, the syntax is the same but the compiler can tell based on the attributes of the component i. This isn't unusual in the language. A reference to X could be a scalar, an array a named constant or even a function. It's all in the declaration.
jimdempseyatthecove
Then (postulation)
 PURE subroutine s2(var)
   var%i = 3 ! (i is pointer)
 end subroutine s2
Wouldn't the above be both pure and un-pure?
Jim Dempsey
IanH
There is a restriction on PURE subprograms (F2008 C1283) that rules out the code in #9.
I expect the bug to be fixed in the 17.0 product release.
