IPO Error: unresolved
francesc_verdaguer
Dear all,
I am installing an air qualitity model called CMAQ.
In the middle of installation I encountered some errors. With the help of diferent people, and this forum, I managed to solve them, but now I have a new one.
It apears this error:
IPO Error: unresolved : pvm_version
Referenced in libioapi.a(iocplf2c.o)
I searched the file referencend, iocplf2c.o and then the source of it. I found the "pvm_version", but I don't understand which is the problem
I attach the terminal outputs, the iocplf2c.o source file (and iocpl.o source file, becaus there are more than one IPO errors), and the Makefile used to help to understand whats happening.
I hope you can tell me what I'm doing wrong.
Thank you for all, and of course, Merry Christmas to everybody
Francesc
xgli
I have probably a similar problem and am looking for an answer.
We know IPO stands for InterProcedural Optimizations. The errors are on those calls to a C library function and probably ipo can not be done between FORTRAN and C functions at level 2 or 3. But it only gives ipo errors on 32-bit build. The same code and library and alsowith -O2 is built OK for 64-bit executable. And even with ipo errors, the 32-bit built executable seems working OK. I guess it is just not optimized. Why 32-bit build is different from 64-bit build? Both are using Intel 9.0 compiler.
-xli
TimP
For the original question, my suspicion is that you don't have a compatible version of pvm installed. The code appears to have been written before the days of MPI. Did you ask the authors if there is an MPI version?
I don't know whether the 2nd post has any relationship, other than that both provoked the bogus "IPO error" which is a catch-all now for almost any kind of link failure report with current Intel compilers.
xgli
Oh, thereason made my guessing two cases aresimilar is by name his library looks likemade of C code too. So I turned to think theremight be issues with doing ipo cross different languages.
BWT, my case is fine if use -O0. So far it is not serious.
-xli
