IPO+openmp = segfault ?
Ted_Rosenbaum
I have been having some issues where when I compile a code with openmp and the ipo flag, I obtain segfaults when I scale up the program. It works fine when I don't use openmp. This is a rather large program, so I can't post a source file, but if any one has insights I would appreciate it.
Ted
IanH
Have you tried increasing the stack size for the program?
Ted_Rosenbaum
Sorry for the very delayed response.
Yes -- i have been using. ulimit -s unlimited
SergeyKostrov
Valued Contributor II
I obtain segfaults when I scale up the program. It works fine when I don't use openmp. This is a rather large program...
How many OpenMPthreads are created? (You could monitor it inthe Task Manager )
How much memory the application used? ( The same as above... )
Could you provide more technical details for a Windows platform?
Sergey
