IVF 11.1 + VS2008 debugger
jr00
VS2008 indicates all compilation errors occur at the last line of one source file in my project. I have tried restarting devenv with different switches (/resetsettings, ...) but it does not resolve the issue. The issue occurs if I compile that specific file as well as building the entire solution and cleaning the solution does not help. Copying the source to a new file and replacing that file in the project does not resolve the issue. The issue does not occur for other source files.
Lorri_M_Intel
There are a couple more pieces of information that would be helpful here.
Most importantly would be the build_log.htm file; can you append that to a reply please.
The other is which compiler version you are using.
              We may ask for more info after that, of course --
                            --Lorri
