29430 Discussions
IVF 9.1 with C++ from VS 2008 or VS 2010
ratel__gilles
Just a question.
Here I have IVF 9.1 and VS2008 and VS2010 (I have also VS2005, but I prefer not install, and prefer use only VS2010), My question is: possible use C++ from VS2010 (or VS2008) with ifort command?
Now If I use Build environnement (dos) for fortran I-32 I get error:
| Intel Visual Fortran Compiler 9.1.024 Build Environment for 32-bit applications
| Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
| Unable to find Microsoft Visual C++ 6.0 or better. <=== PROBLEM
| Intel Visual Fortran Compiler for 32-bit applications will not function properly.
If I look ifortbars.bat
| REM @call "\\Bin\\Vcvars32.bat"
| echo Unable to find Microsoft Visual C++ 6.0 or better.
| echo Intel Visual Fortran Compiler for 32-bit applications will not function properly.
| title Intel Visual Fortran Compiler 9.1.024 Build Environment for 32-bit applications
I change for
| @call "C:\\Program Files (x86)\\Microsoft Visual Studio 10.0\\VC\\bin\\Vcvars32.bat"
But if I test:
ifort -o hello Helloword.f90
I get error
ifort: error: unable to run '\\\\Bin'
do you have hint? a good ifortvars.bat for IVF 9.1 and VS2010?
mecej4
"My question is: possible use C++ from VS2010 (or VS2008) with ifort command?" -- No, because "ifort" is a Fortran compiler.
If you want to compile C source code, you need to obtain and install a C compiler, such as Microsoft's Visual C++, Intel's C++, etc.
Even the free downloadable Microsoft VC++ Express compiler is adequate.
The presence of the string "" in the startup batch file is a telltale sign that the Intel Fortran installer was unable to find an installed C compiler.
Check the list of prerequisites for installing Intel Fortran. If you do not satisfy some of them, but proceed with the installation, some functionality will inevitably be missing.
ratel__gilles
Yes ifort is a fortran compiler.
I don't understand why the error message:
and
ifort: error: unable to run '\\Bin'
Request for C++ is mysterious for me...
The easiest way is to reinstall. (?)
TimP
The visual studio express C++ will be sufficient to support the 32-bit ia32 version of ifort for command line usage only (probably no debugger). Unless you have first installed a supported version of VS2003 or newer, the ifort install won't be automatic.
Wendy_Doerner__Intel
Valued Contributor I
I should note the 9.1 compiler did not work with Microsoft* VS 2008. You will have to upgrade to a newer version of our compiler to use Microsoft VS2008 (also none of our compilers currently work with MS VS2010).
Wendy
Attaching or including files in a post
