IVF Compatibility with Visual KAP
durisinm
I believe that Visual KAP is now an Intel product. You can write a CVF program with OpenMP directives and use Visual KAP to process them. Will Visual KAP be compatible with the forthcoming Intel Visual Fortran?
Mike
TimP
Maybe I don't understand the question. The product which added OpenMP to CVF was known as Guide. Most of the function of the combination of CVF and Guide is already in Fortran 7.1.
I understand the question.
Visual KAP was discontinued two years ago and is no longer supported at all. If it works with IVF at all, it would be a miracle.
But as Tim points out, it is also unnecessary, since the compiler will have integrated support for OpenMP and auto-parallel.
Steve
