IVF10 - MSVS2003 Debugger Problem
jackosullivan
Using my exe compiled from IVF 10.0.026 within MS Visual Studio (Development Environment 2003) 7.1.6030 incl Service Pack 1, I got the following RT error when simply executing with a certain data set:
Visual Fortran run-time error
forrtl: error (65): floating invalid
Image PC Routine Line Source
CE099-4_5.exe 00734D32 Unknown Unknown Unknown
CE099-4_5.exe 00663297 _LNGVALV@8 261 lngvalv.for
CE099-4_5.exe 004423C3 _VALVT@0 777 Valvtjtf.for
CE099-4_5.exe 004D186D _MAIN__ 2518 Mainjv3.for
CE099-4_5.exe 00772515 Unknown Unknown Unknown
CE099-4_5.exe 0071FA46 Unknown Unknown Unknown
CE099-4_5.exe 0074649E Unknown Unknown Unknown
kernel32.dll 7C80B683 Unknown Unknown Unknown
Followed by the ubiquitous Ok, which of course it is not
When I run the same data set by Debug | Start from within the Visual Studio Interface, I get only the following RT error message:
Visual Fortran run-t ime error
and its Ok
After which, the only references I can find in the MSVS Call Stack are:
> CE099-4_5.exe!_for__issue_diagnostic() + 0x3df
CE099-4_5.exe!_for__nt_signal_handler() + 0x74e
CE099-4_5.exe!_for__nt_handler_jacket.() + 0x30
CE099-4_5.exe!fpieee_flt_simd(unsigned long exc_code=, _TEMP_EXCEPTION_POINTERS * p=, int (_FPIEEE_RECORD *)* handler=) + 0x741
CE099-4_5.exe!_fpieee_flt(unsigned long exc_code=65, _EXCEPTION_POINTERS * p=0x00000000, int (_FPIEEE_RECORD *)* handler=0x0008001f) + 0x5fb
CE099-4_5.exe!_main() + 0xc7
CE099-4_5.exe!__QWINForkMain@4() + 0xe
CE099-4_5.exe!_threadstartex(void * ptd=0x01493d50) Line 241 + 0x6
kernel32.dll!7c80b683()
And most painful, I have no locals available in any of my source file listings (lngvalv.for, or valvtjtf.for).
What happened to all the Call Stack references? In particular those between the Call Stacks main() + 0xc7 and Line 261 of lngvalv.for where the non-debugger error message tells me I have a problem?
More importantly, how should I get the debugger to stop where I can see what caused the error i.e., stop right next to Line 261 of lngvalv.for when this error occurs?
Thanks very much and God bless!
Jack
Try rebuilding with the Fortran > Data > Floating point exception setting set to /fpe:0 and see what you get. You may be picking up a NaN from the data set.
You can also use Debug > Exceptions to break immediately on a floating invalid and see if that helps.
jackosullivan
Steve,
Thanks so much for the quick answer.
I was already using /fpe:0, but the Debug>Exceptions did the trick! (Not knowing what 90% of those might mean, I just selected them all.) I was trying to feed a DSQRT a negative number, and now have half a chance of finding out why.
Thanks again for your so dedicated expertise ... or is it expert dedication?... BOTH!
God bless!
Jack
